richardh10
So when you return the anchor chain to the locker, how do you stop it piling up in a mound and blocking the hole before you’ve got it all in?
I knock it over with a stick. Seriously.
Yep, that’s rhe way to do it though I found an inverted large petrol funnel performs well.I have read on here, previously, that some people put a traffic cone at the bottom of the locker, directly under the fall of chain, forcing it to spread out.
I'm really intrigued by this idea of a traffic cone. It fills up the space that would ordinarily be taken by the first lot of chain, which would naturally tend to build up in a cone. So the traffic cone reduces the available volume of the chain locker. How is that supposed to help?
A pile of chain is not normally conical, it forms more of a really stable cylinder. Forcing a cone shape early on persuades heaps of it to go hide in the corners
I use a 4 ft length of 1/2 in stainless poked in thru the deck to move the pyramid.
Works for me.
The alternative was to station the crew in the forepeak with a broom handle working thru the anchor locker access hatch.
... Tony, with 160 metres!
