Anchor Ball
Richard.C
31 Jul 2014
Lincoln
Interested in your examples of how you have mounted an anchor ball on your motor boats?
Most balls I see for sale are designed around sail boats, I was thinking I would need to support one from a post on the pull pit.
rogerthebodger
3 Nov 2001
This post
stainless steel pulpit rail burgee pole
Has been talking about a burgee pole on the OP pulpit. You could used a similar fitting to mount your anchor ball on your motor boat.
If you have the normal 2 piece folding anchor ball you could get a 25(1") tube ans cut cross slots in the one end of the tube to slot the anchor ball onto the tube that then be positioned in the pulpit fitting when at anchor.
Sticky Fingers
21 Feb 2004
Mine is a standard plastic sectional ball. It mounts to a slotted fitting on the end of a pole. The pole fits into a guardrail fitting.
I deployed it last weekend in Osborne Bay. Of the 100 or so boats there only a few showing a ball. And sorry to say mine the only mobo with one.
Seastoke
20 Sep 2011
Once a raggie always a raggie , i leave my anchor light on ,it gives a clue .
Jamie Dundee
24 Jul 2019
I have a ‘rocket launcher’ type rod holder on my wheelhouse roof. I attach the black ball to an extended boat hook and stick it in a rod holder. Visible 360^.
simonfraser
13 Mar 2004
Is this not a historical hangover from sail only ?
a stationary mobo, guess what, it’s on anchor
mobos that move are easy to spot, sometimes moving too quick
raggies can be v slow and are perhaps trying to get somewhere, thats when an anchor ball is more useful ?
Hurricane
11 Nov 2005
Sant Carles de la Ràpita
Thanks for the replies, this is an easy solution, first step is to get a rail mount flag pole and a black ball.
A little more detail.
I bought a rail mounted flag pole from a chandler and fitted it to the hoop on our rail - like this:-
This pic taken from a drone whilst we were replacing the wood teak with synthetic.
Note the fabulous big Rocna anchor under the bow.
And the anchor ball itself is made from a "two piece" anchor ball that you can buy in a chandler.
These anchor balls are supplied in two parts that you assemble when you need it.
I cable tied one part of the anchor ball to some plastic toilet overflow pipe that you can buy at most plumbing DIY stores.
Then using some elastic bungee cord, the second half of the anchor ball can be temporarily attached.
The idea is that the plastic toilet overflow pipe slides over the flag pole.
Finally a length of bungee cord with a loop at the end holds the whole thing in place.
This pic shows it quite well.
Both halves of the anchor ball are there but one is in line with the camera so you can only see one half.
I hope that makes sense.
Scubadoo
Hampshire / Solent
My anchor ball is displayed between bow stanchions, visible from a distance.
You don't see many motor boats with an anchor ball in the solent and last weekend a few motor boats were at anchor during the night without an anchor light and no light in the cockpit so in complete darkness.
Scubadoo
Hampshire / Solent
Maybe it is a hangover, but it is a requirement of the colregs whether a sail or motor boat, without complying could make it easier for insurers to refuse a claim or aid prosecution etc.
Sticky Fingers
21 Feb 2004
That's right. Might be an urban myth but nonetheless, if you're at anchor no ball displayed, and are involved in a coming together with a boat under sail or power, you're already compromised. That boat's skipper and insurers might reasonably claim you bear partial liability.
