boomerangben
True, I haven’t done extensive research on old threads but have followed many. I found the ABYC table before Neeves kindly attached and also the data by another who found wildly different figures. Indeed whilst Neeves has sort of validated the ABYC table with 625kg from his own experiment vs 1400lbs for the ABYC, Neeves points out that the 625kg was experienced as a peak load with an all chain/dynema rode with negligible elasticity. But the moment you put a mixed rode or snubber into the rode, what are the loads? Since peak loads are by definition dynamic, the displacement, mass distribution, underwater profile, entrained mass of water become significant together with the energy absorbing characteristics of the rode. Length provides a pretty poor correlation to the above in my opinion.The loads have all been calculated and measured. The data is available to view from many sources, both attached to YBW threads and externally.
You need to read more anchor threads in the archive.
I am a convert to modern thinking on anchor rodes, have an aluminium anchor with a short length of chain and lots of nylon. So all the loads above, together conventional thinking on anchor mass are left wanting.
I would love to know how accelerations at the bow roller differ between an all chain rode and a mixed rode/snubber arrangement. It is accelerations that make us fall out of bunks, rip cleats out, causes connector failure and dislodges anchors and determines the tension in a dynamic anchoring system. A better understanding of this will lead to cheaper set ups and more comfortable nights sleep (unless you are around rocks and coral of course)
As for the OP, I wouldn’t change the rode, but choose the right size anchor of his choice from modern SHHP or even HHP anchors. Modern anchors rely on the area of the shear plane in the seabed soil around the anchor, which depends on fluke perimeter and depth of burial so oversizing might reduce burial depth and therefor overall holding power. But above all as Neeves says, choose the right anchor for the seabed or choose your seabed based on your anchor.
