ongolo
Running an alternator open circuit may or may not cause problems. As has been said a residual magnetism in the laminates (not the coils themselvs) could result in a voltage being generated.
If the diodes get blown, then not from any current since there is no load, but from an overvoltage developing with no load and no curent flowing, resulting in a braekdown of the P-N junction of the diode.
All diodes have a certain operationg range after which the reverse voltage (in an alternator the current pulses forward and backward) will destroy the diode and be either short circuit or more often open circuit.
Residual magnetism is in fact required when you run an induction motor as a generator. Yes almost any electric motor can be used as a generator!! but that requires the addition of a certain size capacitor , size depending an the expected load and required phase shift.
I should have said the following earlier. A different picture exist when the alternator is connected and running, the field coils are excited and then you open the lead charging the battery, depending on the revs, the voltage could go sky high and the diodes will break down in every case.
I suppose, one could fit 600 Volt diodes and would then be safe, but I am not sure of this one. I have been considering for sometime to mount a diode board outside . I dont think there is a reason other than compactness to have them inside the alternator. Maybe one day.
happy new year
ongolo
happy new year
ongolo
