AntarcticPilot
Yes, for the best effect they have to be precise. But there is an effect even if the lengths aren't ideal. Because both antennae are for the same frequency range (AIS is in the VHF range) they won't be far from the right length anyway, and they will have a wider bandwidth than the single frequency CB band.As a teenager I used to build directional antennas for my CB...my memory was that the elements had to be precisely cut to length and carefully positioned to have any positive effect.
No, because in some directions there will be very little transmitted. And it's not just vertical elements, it's vertical elements that resonate at the frequencies concerned. As both VHF and AIS are at similar frequencies (AIS is within the VHF band) their antennae resonate at the same frequencies.yes but is the loss in those directions not mitigated by the additional height of using the masthead? Also if the two antennas are substantially different in size ( One is a stubby) surely that won't cut off transmitting and receiving totally in some directions..)
Many mast head lights have some vertical metal elements in them do these not cause the same issue..
