Cruiser2B
MARPA is just a machine; garbage in, garbage out and all that. You have to use any machine for navigation with a grain of salt, understand its limitations and know how to interpret and verify the data. It has its uses.
The other thing that takes me by surprise, is boats that just aren't picked up. Although it's only a very few, one is enough (as the Condor tragically found out a couple of years ago). I've had one small open fishing boat and two small yachts that simply hadn't registered on the radar.
And at this stage, please don't get me on radar reflectors. Suffice it to say the only ones I've ever picked up in any of the tests we've done, are the active reflectors. Without an active reflector, I'm told the main reflecting surface from a yacht, is the hole it makes in the water.
if radar reflecters are so poor, how come there's only a very few yachts you haven't picked up on RADAR?
It also ganged up with the plotter as it kept telling me I was turning left while I kept thinking it was barmy and why does it keep saying turn to starboard. The radar confirmed the plotter's superior sense of direction
feel like you are the centre of RAF command during the war.
.....I don't suppose anyone, who has posted a reply, has used MARPA or AIS in crossing a busy shipping lane in poor visibility with 2 people on board. If anyone bothered to look at the picture on the opening post, there are 7 ships present....
I am, quite frankly, surprised at all the replies on this post. I don't suppose anyone, who has posted a reply, has used MARPA or AIS in crossing a busy shipping lane in poor visibility with 2 people on board.
You may be worrying too much, the chances of 7 ships bumping into you are very small.
I am, quite frankly, surprised at all the replies on this post. I don't suppose anyone, who has posted a reply, has used MARPA or AIS in crossing a busy shipping lane in poor visibility with 2 people on board. If anyone bothered to look at the picture on the opening post, there are 7 ships present. The picture is cropped and there were 3 more going East. Taking out paper and plotting lines is simply not possible. Marpa, with acquisition of up to 10 targets, is quite good especially when the range is down to a mile or 2. AIS, from my first trial is better. Hasn't anyone else done a comparison. Surely I am not the only boat to cross the shipping lanes using both. I am looking for some tips on what collision ranges to use etc. With 2 miles on that picture you can see there were 4 ships in collision zones at the same time. How could it be handled better?
I would be hesitant to use AIS as my primary method of anti-collision, as it bases its calculations partly on your own supplied data, and partly on the data supplied by the other ship - there's no way for you to verify that the other operator has his system set up correctly.
Following on from the ground-stabilised/sea-stabilised discussion, I would also be concerned that while your class B set will be ground-stabilised (taking course and speed from the GPS), class A units are required to have a compass/gyro-compass input, so the course data from the other ships might be sea-stabilised (or partly).
This is true up to a point, but it's not as if the other ship has someone manually typing in its course and speed every five seconds, who might make the odd typo. AIS transmitters are required to have their own GPS receivers, so the crucial position, speed-over-ground and course-over-ground information is more or less independent of any action or omission by the crew. Yes, they regularly seem to forget to change the navigation status, so you get "anchored" ships proceeding up the Channel at 20 knots, or closing on the Nab Tower with a "next port of call" in Caracas, but those pieces of manually-entered data are only really of casual interest to yachts. It's the position, CoG and SoG that matter, and the black box manages those without crew input.
Even so, if using AIS for collision avoidance you're basically relying on a CPA derived from the calculations from your own AIS box which is based on the information provided from your own box and those transmitted via VHF from another box on another ship, all of which potentially have multiple inputs and if any one of those multiple inputs and calculations are incorrect then the information spewed out by AIS is worthless. Compared to radar there's far more things to potentially go wrong.
They don't have "multiple inputs", they have a GPS receiver each. Which, yes, can suffer inaccuracies, but rarely do.
A radar system doing MARPA actually has more inputs - log paddle, fluxgate compass, perhaps a rate gyro, the rotary encoder that tells it which way the antenna is pointing at any given moment, perhaps some mounting offset, before we even get to the whole magnetron / reflecting target / receiver combination. And some of those inputs (particularly log and compass) are not just theoretically subject to inaccuracy, they regularly are inaccurate, to the point that knowledgeable people like Piers won't use them at all. It also requires a fair bit of operator skill, experience, and concentration.
The fact is that the two systems complement each other. AIS requires a certain amount of cooperation from your targets, but is highly accurate when it works, most of the time. Radar is less precise, but is self-reliant whatever the muppets on the other vessel are doing, and picks up the small fishing boats and (hopefully) yachts that don't have AIS (and it has navigational uses, but we're only considering collision avoidance here). Both are subject to technical faults and failures, but generally not in an interdependent way, so they back each other up.
Well actually it does, the AIS on my ship....
Speaking from personal experience, I would never, ever, rely on AIS for collision avoidance, nor use it as a backup; it's really there as a curiosity and early warning tool. The most sensible backup to Radar is compass bearings, whether they be via repeater, hand held or EBL (be they relative or true).
Curiosity - assuming your ship is commercial, what is your ship and where does she fit in the spectrum from well funded bridge with ECDIS + all bells & whistles to bare essentials with RADAR + eyeball + whatever is mandatory?
ECDIS is a minefield of potential cock ups as it's possible to remove detail such as wrecks, shoals and the like from the screen and merrily sail on, so unless ships staff are fully aware of the same we're going to be seeing a LOT of 'ECDIS assisted' groundings over the next few years. Naturally it'll make the red line merchants even worse.
It's my understanding that even when we have ECDIS fitted in a few years time it will be the policy of my employer (in common with a good few others) that ECDIS will not be our primary means - we will not go paperless - it will merely be there as another aid to the paper chart. Lots of very sensible reasons for that as I'm sure you can imagine
No, the gyrocompass provides the heading. The course over ground comes from GPS. Both are reported, so your receiver can display the data however it likes (for example it could present separate track and heading vectors out of the other ship, like you usually see out of your own on a plotter)
