Advice servicing an old Lewmar winch
Rolling Stone
27 Jan 2023
We have some old Lewmar winches which we need to service. Having never done it before, looking for advice on how and what to do.
Thanks.
Boathook
5 Oct 2001
Surrey & boat in Dorset.
I thought that my lewmar winches were old but they look 'modern' compared with yours @Rolling Stone . When you come to service it, I would put a fairly tall box round it taped to the deck to catch any small parts that may 'spring' out.
Latest PBO has an article about servicing 'modern' winches where they mention a box.
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
Looks like undoing the four screws on the top would be a useful start. I doubt that many have any experience of such old kit, so you will just have to feel your way. As said, making sure you don't lose anything is essential.
Rolling Stone
27 Jan 2023
We had a discussion at St Kats over the weekend wether to pollish or leave weathered... concensus was weathered, there's a natural beauty to them.
Good idea re the box. We couldn't see any other way in apart from the screws at the top. Not aware we need any parts, they all work fine except they groan when spun quickly.
KevinV
12 Oct 2021
Couldn't agree more about leaving the patina, it's lovely.
Be very sure you have a perfectly fitting screwdriver, file one down to fit if needs be (preferably an old fashioned impact driver), you can't afford to mangle them. A week of daily penetrating oil would be a good idea too - make a plastacene dam if you have to.
Good luck, I for one would love to see some photos of the innards
Alex_Blackwood
19 May 2003
Fareham
Thanks.
Once again, Dr. Google is your friend. Do a search "Servicing boat winches" loads of UT etc. Of course there are variations but winches are basically all the same so you can get ideas of what to be aware of.
Biggles Wader
3 Mar 2013
London
If they work well I would limit any "servicing" to taking the drum off and just lubing the moving parts. I regularly drip a little sewing machine oil on mine.
ghostlymoron2
12 Sep 2023
If they're stiff, they're probably caked in solidified grease. I degrease mine in paraffin before applying new grease VERY SPARINGLY to bearings. A few drops of oil on the pawls. Obviously replace any broken parts (if you can get them).
vyv_cox
coxeng.co.uk
Springs that work reasonably well can be made from rigging wire. The wire is hard drawn for strength but can usually be bent enough to form the required shape. Heating it will anneal it, destroying the springiness.
Refueler
13 Sep 2008
Far away from hooray henrys
Thanks.
PLEASE PLEASE before dismantling .... take a box and cut it so you can place it round the base ... then it can catch any pawl / ball bearing / spring etc. that wants to go walkies !! Or a plastic bag .... anything that stops you losing that bit !
Wakatere
10 Aug 2005
Solent
I will make sure to take some pictures for you :)
Hi @Rolling Stone, did you succeed with the winches?
I have a pair I took off the boat (in working order) when I bought self-tailers and I've always intended to service them prior to selling them.
Edit - that made me go downstairs and take them to pieces - I think I shall have to make some springs.
Halo
10 Nov 2009
Wetherby
I had some of a similar vintage.
I used the same practice as is advised for modern winches - strip down- rinse everything off in paraffin using a shallow container and a paintbrush. Dry , lubricate with waterproof grease ( oil on pawls)
In my case a couple of springs had snapped. Fortunately I found a biro spring would cut down to just the right length and worked great. I replaced these each year in case of corrosion as they were not stainless.
Rolling Stone
27 Jan 2023
Not yet started, other jobs keep cropping up. It's on the list to do.
