Nostrodamus
Thank you for all your replies which helps me understand the problem a little more. There appar to b no definative answer but it seems as though sometimes we either just have to experiment or compromise.
My engine as was suggested seems to rev to about 3600 which when matched to the old Volvo 120 leg was fine. It is the new leg and gear ratios that is causing me real problems and now the 120 leg is out of production others may well have the same problem.
old leg gear ratio was 2.24:1
new leg ratio is 2.19:1
I know I need more bite when in marinas etc. In no winds or strong tides I can take things easy but if I really wanted some grip when manouvering forward there is nothing there.
Pitching the prop up is going to loose me 200 RPM for each notch. This would be good for manouverability but may strain the engine or loose me the ability to be able to punch through a sea and may leave me feeling I am in 5th gear all the time.
I try, like everyone not to be in really rough weather but at some point I will be. I usually cruise at 2,600 revs.
I am still in a dilema as to how best to cure the problem and have even concidered changing from the Bruntons variprofile i have to a fixed prop.
I suppose the only thing I can do is try changing the pitch and see but I don't want to spend a fortune adjusting something if then I have to adjust it back.
