adding spectacles to an existing main
SteveSarabande
3 Apr 2012
Solent
I am trying to get a rough idea of what the going rate would be for a sailmaker to add spectacles to two reefing cringles to an existing mainsail on an 8m yacht.
Anyone had this done recently?
JayBee
15 Sep 2004
I had this done a long time ago but can't remember the cost. For two reefing cringles the materials amount to four stainless rings and perhaps a metre of webbing, plus the sailmaker's time, say one hour.
JimC
30 Aug 2001
Lancashire
I've no confidence in my own stitching but I have done it experimentally with 8 mm rope and bunt-line hitches to the rings, shortened up as much as possible. It looks OK, haven't used it in anger yet though.
alahol2
22 Apr 2004
Portchester, Solent
www.troppo.co.uk
A much easier, cheaper solution is to just splice a ring of three starnd through the cringle. Used on the last 2 boats very successfully, cost... about zero.
I suppose you could also go for one of these new fangled soft shackles through the cringle.
webcraft
8 Jul 2001
Cyberspace
www.bluemoment.com
Remember the luff will be slightly longer when reeefed than previously - it might make a significant difference to the shape of the reefed sail as the leach cringle will remain the same. It might be worth DIY-ing with rope at least temporarily and trying it out before committing.
Just a thought, not based on personal experience - we had our main made with spectacles.
- W
wotayottie
1 Jul 2007
swansea
Genuine question but why would you want to do so? I have them on my main, I can only get one ring round the horns anyway so they achieve nothing much
Lodesman77
22 Sep 2008
Cambridge/Pin Mill
Opinions vary, but among others 1) it's much easier than trying to get the cringle directly onto the horns, and 2) it should line up the pull on the sail better.
Why would you want to get more than one ring on at a time?
simonfraser
13 Mar 2004
Dunno how much tension u guys need on ur luff, but I distort my reefing holes with the spectacle rings as they pull off axis when hooked on one side only.
Have replaced them with single line in a small loop, dyneema, knotted.
rob2
23 Aug 2005
Hampshire UK
If you're worried about your sewing skils for a DIY installation, then consider that the strain is actually taken by the webbing being laid upon itself to form a coil - the friction takes the load with the stitching only needed to keep the layers together.
I have spectacles on my new main (which I didn't ask for) and am contemplating taking them off as I use single line slab reefing.
Rob.
SteveSarabande
3 Apr 2012
Solent
A loop of rope is my other option., maybe i will give that a go first.
At the moment there is no reefing system, so i am just working through the prices and options. The main has reefing cringles but there are no ramshorns, lines, blocks or anything on the boom. The previous owner just used a bit of old rope to tie in the reefs. I sail singlehanded mostly and need to make it quicker and easier.
Lodesman77
22 Sep 2008
Cambridge/Pin Mill
Why are you thinking of taking them off? Everyone's set-up is different, and clearly they don't work for simonfraser, but mine seems to work as intended and holds the sail nicely. I also use slab reefing - seems to me the reason to use them rather than to remove?
If I didn't have them I probably just use a loop of rope, although on reflection they probably help to avoid chafe to some degree...
