ghostlymoron
The diagram is wrong. Over the tops of the pulleys, there are only two strands which are taking all the load as the tension must be transferred through the rope. Statically it doesn't work in my view.
If the string in the picture has a breaking strain of 50lb you can still use it to lift 150lb if it is trippled up .... any single strand still has a breaking strain of 50lb.
With a 3-strand splice on a link, with all 3 strands used you have doubled up to 6 strands on the link itself, so the attachment at the link is stronger than the rope - even though the double-back on the link weakens the strands (and why for a really strong splice you would use a thimble.)
Because it is a splice, it tapers back to 3 strands of the original rope - the 3 strand rope remains the weakest link, not the splice.
If you only use 2 strands, then that is doubled up to 4 in the splice so it is still pretty much as strong as the rope itself which is only 3 strand. With the doubled-back strands weakened, it appears to be 97% as strong as the original rope - which is close enough to be considered workable.
That is the theory behind the 2-strand claim, I don't particularly like it and used all 3 strands on my splice, but it appears correct.
Perhaps someone more knowledgable can provide clarification.
