Hooligan
I should add that @petem is almost certainly correct, so last point not relevant. In any case as @kashurst so eloquently put it - do not hesitate. I give thanks to my Grandfather every time I jump on a plane.I also had same situation ie right for an Irish passport which I gratefully accepted. No have a boat in Greece although it was in the EU - Italy - over B ye so VAT ok. Herewith my thoughts
1. The Irish passport means no 90/180
2. The air ish passport means you are sipping Pina Coladas on the beach as the rest of EasyJet is clearing immigration. Heaven
3. If boat is considered VAT paid then nationality is irrelevant as everyone suggests already
4. To the point above that I believe is a matter of how you choose to play it. You have the luxury of choosing which passport you use. Therefore I believe that @Hurricane point is valid ie your boat could be considered a U.K. boat. BUT if you use your U.K. passport then it is not unless someone decides to investigate which I can assure you won’t happen or at least very very unlikely. So I think it is all about your risk tolerance versus paying another VAT charge.
