6mm chopped strands of fiberglass
Rhylsailer99
19 Jun 2020
Is this ok to add to 6mm chopped strands to west system epoxy resin to fill in some small areas that would need more strength or should I just stick with colloidal silicon.
If it needs more stiffness then the silica would be okish, but if you need tensile strength add the fibres - not nearly as good as proper cloth, but better than nothing!
Would not use chopped strands for filling - it is the wrong thing as you don't need the strength it adds and it is a pig to get a smooth surface. Use either silica and microbaloons or lghtweight fairing filler if you want to mix your own or International Watertite. The latter is easier to use and gives a good sandable finish.
It's a good way to go for some things like chips in Laser centreboards.
Use glass bought chopped or cut it from tape or clotch not mat, as the binder in most mat is not right for epoxy.
It's a case of shaping it with metal tools, it should set quite rigid.
If you don't want the strength of glass, glass bubbles or microballoons may be better than silica for many jobs.
I've found microballoons or similar still hold up best with some silica added - it seems to prevent the epoxy from sagging at a comparatively thinner consistency than with microballoons (or indeed milled/chopped fibres) alone. This is especially useful when you want a thin consistency for final fairing.
West low density fairing filler is a mix of (some sort of) balloons and silica, for this purpose, I believe.
It really depends on the application. More detail would help. There are times when glass fibres in resin and silica is a good solution. Resin and silica is brittle on its own and will crack eventually in an application that needs some structural strength. If you are filling and faring something none structural then micro balloons are the way to go as its easily sandable unlike silica.
If you need structural strength, go for the glass threads. It'll be seriously tough (impossible?) to get a really good finish on, but use it for the strength and a bit of epoxy filler to finish, which could be the same epoxy with microballoons, and you can get it as perfect as you need.
Its at the top of an encapsulated keel where it joins to the boat a big chunk of gelcoat has come away exposing fiberglass strands and there is a gap like a void . I'll take a pic today of it.
Really doubt you need to add any strength there then - gelcoat provided almost none. Go for microballoons for easy fairing. Colloidal silica is hard work.
Its the longer strands of glass mat that provide strength. That said, I always have a bag of chopped up small strands of leftover mat for just this sort of job - bulking out a filling with more strength than thickened epoxy alone will give me. Or P40 or Fibral body filler is even easier to work with and sticks surprisingly well if the old glass is cleaned with acetone and keyed.
It'll need fairing off. Epoxy thickened with microballoons is good.
I would clean the old mat up with a flap sander on a grinder. If you cant get in to the void maybe use sanding discs on a Dremel. Vacuum the glass when done. Wet out the glass with unthickened epoxy. Mix in some micro-balloons and apply that to the hole. Sand back when hard and apply some epoxy primer ready for antifouling
i have not got any micro balloons but have west system collodial silca ,micro fibres and fairing compound, i think maybe the silica would be best option.
West fairing compound is a ‘microlight’ filler (akin to - if not quite the same as microballoons) with some silica added. The brown stuff is the microlight, the white stuff is silica.
So you’ve already what you need, I think!
