tudorsailor
Sounds interesting - here are a couple of photos of the "bung" showing the sizes. It would have to be flexible/rubbery as you say. The idea is to hold the T section of the shroud terminal in place whilst lifting or lowering the mast when there is no tension on the shrouds. Once the terminal is inserted into the mast the bung is fitted and as can be seen in the photo,View attachment 81389View attachment 81390 there is a flat side that surrounds the hole in the mast and a bulbous bit that inserts which is slightly larger than the mast hole ( hope that makes sense!)
It is a bit difficult to see the detail from your photos
Is the bung that you photographed a spare? If you sent it to me, it would be much easier to try and model. Once I have seen it, I would send it back by almost return
PM if you'd like my address
Do you have a photo of a bung in place?
TudorSailor
