Zing
Sponsored maybe? Those Victron lithiums (like Mastervolt) are ridiculously overpriced.That's a lot of blue. I think Stephanie is considerably better endowed in the wonga department than me. Looking forward to part 2 though.
sit back and wait, wont be like that for long I guess!Sponsored maybe? Those Victron lithiums (like Mastervolt) are ridiculously overpriced.
loving this, just had conformation my Lifepo4 cells are on there way from China so will be joining you on your journey ?❤
I saw on facebook there was concern of RJ Energy shipping out used or B rated cells with the cell QR scratched out.
I was concerned about mine considering they had a scratch or two on a terminal here and there, and a different colour cell wrapping on one of them. The original etched QR codes are all intact though.
I will ? hoping to put the hole thing on my Youtube channel.
re the balmar i have purchased the balmar 614 in readiness, im guessing our usage and setup is a little different to yours as we are a motor boat on the thames and generally we go out most weekends and for a few weeks over the summer. my plan was to have the Balmar's absorption and float voltages to say 3.5v / 3.6v so whilst we are using the boat we have a reasonable State of charge we can make use of whilst we are away and then set our shore power charger to absorb and float at 3.2 / 3.3v we leave the fridges on all the time so whilst we are not using the boat they will discharge to a comfortable storage voltage.
i am in a quandary as to which BMS to choose
I originally planned to go with RJ and had good communication with a lady there called Alice who emailed me pretty much daily and then suddenly disappeared and dint respond
I then heard a lot of good things about Xuba on Diy solar forum who "apparently" sell EVE cells which are "apparently" good I spoke to someone there called Amy who has been amazing, they had a special deal running and i got a great price on 8 cells that i plan to run as an 2p4S 560ish AH pack they even send you a personal picture and test video showing the voltages of each cell which is a nice touch i also ordered a custom case for my batteries
so i like the app and interface for the 123 smart bms however i am not a fan of the boards and the use of a relay always consuming power plus the wiring to the boards and the relays seems a bit like a science project with the push small fit connectors.
the Rec and orion seem very expensive
the new Daly FET based ones look better and can now do higher amps upto 300 but not sure how much faith i want to put on them with my nice new Batteries and boat
chargery originally seemed positive but is expensive once you add in the Contactors and after watching Will Prowse's video on it and the terrible screen Ui i am put off
my current plan (subject to change) is to use a JBD 150A FET based BMS as they seem to get good feedback on the forums and test it over the winter at home and then switch to a 123 smart if it doesn't meet the grade
i need a maximum of about 100 - 120 amps through the inverter for the immersion heater in the morning for showers so hopefully have a little head room
I was looking at the 123 smart in conjunction with the 200a victron smart battery protect relays that should be ample for my needs and low power consuming, though will get it all top balanced and built and see how this JBD / overkill solar one performs before splashing more money on the 123I don't know that BMS. Would be interested to hear a report when tested.
Not everyone appreciates the 123 boards - usually people complain about having to solder on their own wire! the interconnecting push fit connectors do look a bit alarming at first sight but the connections are sound (having tried to pull one out without the special tool). Actually one of the attractions of the 123 smart relays are that they are bi-stable and therefore very low power. They are rated at 120 amps so probably not enough headroom for your use.
i don't think their BMS would work with a DIY Lifepo4 setup however their battery protects as a larger amp low consumption relay instead of the 123 smart relay is very interesting
