KompetentKrew
As I understand it, his current weekend sailing is only using a fraction of the bank's capacity, therefore he's keeping it at half charge to be kind to the batteries.While I understand you are in the early stages of use for your pack I am a little bemused. If you are going to only charge to something around 50% capacity of your pack your available energy is only 50% of the maximum. Are you saying you designed a pack that has twice the required capacity in order not to need charging close to full capacity?
For longer term cruising he can charge to 100%, use them normally and run them down, enjoying the full capacity.
Good:
- Keeping the batteries around 30% - 70%
- Charging them to 100%, slipping lines and discharging as deep as you want. 100% -> 0% -> 100% -> 20% -> 100% -> 45%
- Storing the batteries at 100%
- Staying on shore power for months and keeping them in the 98% - 100% range
