NickTrevethan
Hi there,
This is probably a question for Halcyon but anyone else have an idea?
I am looking to fit an electric head to the forward heads compartment my Sealine 365.
It draws 20 amps so I reckon I need a 16mm conductor at the least from the battery switch to a breaker. I had hoped to use the existing cable run, but looking at the back of the 12 volt panel, rather than the one big cable coming in from the battery to a single block then distributed to the panel all I see are 4 much smaller cable carrying the +ve to the various panel supplies.
How were these things originally wired? I can’t see a really heavy duty cable running through the engine bay forward so I suspect several smaller cables were run.
Would it make sense to run a single 25mm (AWG 5?) cable from the battery switch to an insulated buss bar/stud and then cut and connect the four cables to the panel from the buss bar.
I guess I’d need to beef up the ground too.
Other solutions? I thought about a battery in the forepeak. But have no idea how to wire into the charging circuit. I guess I’d buy a mains charger, but would also need to run a supply from the alternator, which would also have to be a decent size given it’s probably 10-12 metres in total.
