davethedog
Hello all and just after recommendations for a 12v foghorn system for a sailboat. Already have a set of wiring ran up the mast and into the boat for a speaker to be fitted.
Cheers
DTD
Cheers
DTD
There's a mistake in your calculation; I think you've slipped a decimal place and it's 10.5 Ah per hour.I doubt the amount of power used is a huge issue*. Even horns powerful enough to be as much noise as you'd want to tolerate on board (might need some ear plugs/defenders) don't draw that much, and you'd only normally be using a it few seconds every couple of minutes.
I've been intending to mount on my boat a compact but scarily loud horn I previously bought for a motorbike but never fitted. Ideally I'd want it on the pulpit, as far away from the crew's ears as possible, but I suspect it would have a limited life in all the salt-water spray and be vulnerable to damage. I was therefore contemplating putting it in some sort of a downward facing hood on the front of the bottom of the mast.
I would still carry an emergency pump up or blown horn as a back-up/supplement, but they are pathetically feeble in volume.
*p.s. Stebel Nautilus horn, advertised as 139db (ouch!), apparently draws 18 amps. I reckon that would work out roughly equivalent to a continuous draw of 1amp over the period in use. (I'm v. tired so might need to check my maths etc.: Sailing vessel in fog 1 long @ 5 secs + 2 short @ 1 sec, every 2 minutes = 3.5 secs per minute = 220 secs per hour = 0.583% of the time. 18 amps x 0.0583 = 1.05 amps.
Little Sister erred in that it's 5.83%, not 0.583% however the value she actually used in the calculation of 0.0583 is correct, as is the end result of 1.05 Amps per hour.
18A over the length of wiring to run up the mast will involve some power loss though unless the wire is a fairly heavy gauge
I'd forget the automated novelty.
What happens in fog is you want to listen.
You don't want your own toys going off just when you think you hear something.
I'm about to wire up a loudspeaker to my Icom M423 to see what its foghorn function is like. But the manual says just 10W output, so I'm expecting it not to be very loud.Anyone using the foghorn option on an Icom gx2100e?
Manual says it can listen as well through the speaker.
Despite some people expressing scepticism, I'd be interested. Its not a huge premium to automate a chore that can take attention away from scanning for dangers by ears and eyes (including AIS and radar screens). LittleSister's calcs showed us that the horn would be sounding 6% of the time, so I'd be listening 94% of the time without losing attention to fiddling with equipment. A pretty fair tradeoff, I think.I've just been chatting with a colleague, and we reckon we could put a system together for around £50.
This would include the horn, and a control box with simple functionality. Select the type of signal you need ( sail / motor ) and hit go. It would then produce the correct signals at the required intervals until told to stop.
Anyone interested?
Edit: we should probably add a manual trigger button as well!
My experience is that I've hardly ever heard other vessels sounding horns in fog, including two recent foggy crossings of the Straits of Gibraltar, really busy with shipping.
I'd sooner give vessels a chance to avoid me cos I'm reliably making a racket rather than trust that I'll hear them. Because experience tells me I won't. Experience also tells me that I can't sustain hours of regular foghorn button pressing.
Just back from testing. Audible range of the 10W output into a 30W horn speaker was 250m or so in line of sight standing in front of the speaker.I'm about to wire up a loudspeaker to my Icom M423 to see what its foghorn function is like. But the manual says just 10W output, so I'm expecting it not to be very loud.
Yeah, I wish my Icom could put out that much audio. Mind you, 30W audio output is a fair chunk of power for small devices like modern VHFs to deal with alongside the hardware to manage 25W of radio output. Well it was when I used to run to hi-fi amps and VHF radios that I could repair thirty years ago. Stuff is more efficient nowadays.Lots of VHF radios have built-in automatic foghorn functionality, typically with 30W output. Worth checking your VHF specs first.
I'm with you on that. Mostly because of the thought of big b*ggers like you scraping small b*ggers like me down the side!!Always hated fog at sea ... eery feeling.
Just a story that may amuse ....
20,000 tonner going into Placentia Bay Canada ... dense fog ... I'm up on focsle with an AB keeping lookout for bouys ... bridge calls on walkie talkie ... keep eye out for stbd marker buoy should see it soon ...
AB and I looking ... staring into the dense fog cannot see a thing ... then we hear BONK BONK BONK ... as it dances down ships side !!
