Refueler
I'm familiar with rule 34 (actually *both* rule 34s but let's not go there). What I was questioning (and I may have misunderstood) is the implication in refueller's earlier post that your own sound signals should somehow be different after you "make audio contact". If nothing else I'm not sure how I would know if/when another vessel could hear me. I'm sure there are plenty of conventions applied by masters of large commercial vessels which arent In the colregs but that doesn't make them best practice for small yacht sailors
The sound signals are as per ColRegs ... that is the foundation. No dispute.
My comment is that once audio contact is established - its possible that blasts and answering blasts made to enable each to pass or avoid safely. It is not a case of just doing what you imagine to do ...
Long debates in Marine colleges over proceeding in restricted visibility ... not only sound signals - but also speed. When the rules changed in the 70's ... they introduced the questionable 'Radar assisted vessels may proceed at higher speed than those without' - that caused a real debate for years ...
The fundamental function of the ColRegs is to define a minimum standard to follow. To avoid close 1/4's situation. Same as Highway Code on the road.
