This was discussed here some weeks ago. It seems it is a known problem and Lagoon are dealing with it.I watched that yesterday, it will be interesting to see how it happened.
Strewth, this problem is a lot worse than I thought, also the repair kit is rubbish. What they need to do is provide a kit with real fiberglass or fiberlam panels, along with the glass cloth and 2 comp epoxy to install them. If it's all cut to shape including the tabling to attach the boards, it's not too long a job to install, unless its in a difficult area to acceess due to the need to remove more of the interior. I wonder if using a good 2 comp foam would work.that looks like rather poor plywood is used. Assuming it is around 15-18mm 7 thick layers breaking like that doesn't look good.
Pretty sure 18mm marine ply has more (and thinner) layers.
all imho
This is the list of activities they are going to use to dodge paying for the repair:
• Sailing out of the Owner’s Manual sailing advice:
◦ Sailing with more sail area than allowed on the Owner’s Manual sailing advice
◦ Powering against sea and wind for a long time @30° off the true wind
◦ Sailing in very shallow waters to a point where waves could end up in occasional groundings
◦ Anchoring in very shallow waters to a point where waves could end up in occasional groundings
◦ Grounding
◦ Tightening the rig out of the mast manufacturer specification. Check the Dock Tune
◦ Improper haul out and storage (Owner’s Manual)
Wild guess, but the type of repair involved would cost around 10K. It's delamination of the hull that can be far more serious and even Boston Whaler when they experimented with a 31ft sports fishing boat had to write one off for serious delamination. BW are a good company so they did not argue that the boat had been subject to abuse, or extreme sea conditions, which it had. They just sent out a surveyor at their cost and paid in full. I was using that nice boat, but noticed the fridge was hitting the inside of the hull in bumpy conditions. Once we were back in the marina, I called the owner to take a look, and he then did a mental act on the phone to the UK dealerr in Poole. That's was not needed as they would have paid to make sure their reputation did not take a knock.This is just Lagoon squealing 'not our fault' as a presage to the inevitable class action lawsuit that's coming. Not 'Powering against sea and wind for a long time @30° off the true wind'. Really? Are they selling ocean going sailing boats, or canal houseboats? Has there ever been that restriction applied to any other kind of boat (it didn't seem to do my Dragonfly any harm)? Do they seriously expect that usage restriction to stand up in court?
The cost of proper recompense or repairs (not their half baked fix for boats where the bulkheads haven't broken yet) for the failed 450's is enough to put the future of the company in doubt, let alone the sales hit from a complete loss of confidence in the brand. If it's other models as well, they are done for. I hope they are set up as financially independent of their parent company Beneteau. There's going to be trouble ahead.
My friend Bob who was the technical man at Leros Marina told me of countless construction problems with Lagoon cats. They seem to be very lightly built.
Leave Catalacs out of it. Mine likes salad and is always trying to loose weight !Lagoon seem to have mastered the combination of a lightly built boat that at the same time is grossly overweight. A 45' cat that is pushing 16 tonnes dry weight - strewth, no surprise that they sail like a salad dodging Catalac.
The Outremer 45 weighs 8.7 tonnes, Fontaine Pajot Elba 45 10.8 tonnes, Broadblue Rapier 550 9.5 tonnes, Dragonfly 40 4.8 tonnes.
Friends of ours have a 15t cat... but it's 72ft long!Lagoon seem to have mastered the combination of a lightly built boat that at the same time is grossly overweight. A 45' cat that is pushing 16 tonnes dry weight - strewth, no surprise that they sail like a salad dodging Catalac.
Catalacs aren‘t badly built nor have pretensions to grandeur, or performance. Their owners know what they bought. The onboard space/cost ratio cannot be beaten. And the bulkheads don’t fall to bits.Leave Catalacs out of it. Mine likes salad and is always trying to loose weight !
