Remove the heat exchangers, manifolds, hoses, the alternator and the pullies. Tape over all the holes. Degrease with gunk (in a spray can from car spares shop) then wash off with water from a pump-up garden sprayer (you can squiry into all the crevices with this without using excesdive quantity of water. Use a range of different wire brushes in a cordless drill to abrade all surfaces. Degrease and wash again. Paint using Hammerite Rust Beater primer by brush then two coats of Hammerite smooth paint by brush. This worked for me and still looks good after 16 years. Obviously, you will get to more areas if you take the engine out. Do the heat exchangers, etc, at home but use the Hammerite special metals primer on anything aluminium.Hi looking for reccomendations for best way to clean and repaint the engine pictured, do I need to strip the paint or can I paint over. Plus what products do people suggest for best results
Thx
Good point. Caution with any flammable solvent that does have a way to drain.Be very careful, some degrease,s are petroleum based!and you don’t want that in your bilge.
