robmcg
What are the weak points on the Bukh dv36 engine? Are there any known weaknesses? Would the freshwater cooling conversion have helped with longevity? Anything I should look closely at?
Cheers
Rob
Cheers
Rob
This is hearsay,worth checking though: The fresh water circulating pump seals can leak,allowing coolant to leak INTO the engine,contaminating the oil. Apparently not visible from outside,double check for mayo!
Apart from a year or so in the Caribbean a decade ago she has been in and around the Clyde for a long time. We have had her on the East Coast (of Scotland) this year and she is going to the west, near Oban, next season.Thanks for the vote of confidence Ken. I am sure I have sailed past Cherry Ripe on the Clyde. Are you based up there?
These engines are approved for installation in ship's lifeboats, a recommendation that must carry some sort of weight I think.
I think that's definitely hearsay. The freshwater circulation pump is external, driven off the back of the seawater pump and it's hard to see how even a catastrophic seal failure would let coolant into the crankcase. Perhaps a different engine.
Sounds like you might be getting mixed up with the injection pump seals leaking ??This is hearsay,worth checking though: The fresh water circulating pump seals can leak,allowing coolant to leak INTO the engine,contaminating the oil. Apparently not visible from outside,double check for mayo!
Also does anyone know how good the standard gearbox is in terms of output bearing issues. It does use hydraulic fluid, BUT I get the impression it's a simple manual box like the Yanmar 2GM. So if that is the case, has anyone had any problems with gearbox bearing or seal failures ??
I've noted the points about fitting top quality circulating pump parts
He mentions keel-cooling so he won't have an impellor to change(obviously the circulating pump has an impellor, but it's not a service part).Presumably you are referring to the comments by Jerrytug in post #4 (which relates to the way the seawater pumps are mounted on the DV10 and DV20, not the different arrangement on the DV36), and by Ashley in post #9. The latter does relate to the DV36, which originally had the seawater pump somewhat hidden above the oil cooler on the stbd. side of the engine. I note that the current version of the DV36 has a very different arrangement pictured on the Bukh.dk website, with a belt driven seawater pump mounted on the front of the engine. That should avoid most likely problems, if the engine you are considering has that arrangement, but periodic check and replacement of the impeller is still important, as it is on any engine.
Many former lifeboat engines have keel cooling only, and I want the boat I am building to be both ice worthy and capable of running the main engine whilst beached, or hauled out. One conversion I will be making is to fit a small car radiator and fan with a Y valve, so I can select between cabin heat or keel cooling. I'm also going to look at how I might fit the cooling plate inside the aluminium hull, rather than outside.That's correct for keel cooling, but that is so rare on leisure boats* I suspect it's just the engine is described so by the seller as 'keel cooling' as that's what it was originally set up for (i.e. an ex-lifeboat engine, presumably). Unless he's actually got keel cooling on his boat, he'll also need a heat exchanger and a sea water circuit, including a sea-water pump.
*(Except for canal narrow boats, perhaps?)
So the only real question now is about the hand start option, and which exact models are available.
On my 1979 DV36 the hand-start 'option' just involves buying a crank handle (and perhaps a gym membership!). Bukh spares being what they are, the crank handle was about £100 last time I looked, but it's simple enough that someone with engineering skills and equipment could make their own.) On my engine the handle can go in either at the forward end of the engine (top side port), or the aft end, roughly above the gearbox, to suit your installation. A shaft runs between the two ends, and if I recall correctly is connected to the engine by a chain.
I'm not sure that hand-start shaft is now standard, and it, or some substitute, may now be an optional extra.
Marine Enterprises also have Yanmar ex lifeboat engines which are also sometimes keel cooled. There are also keel cooled versions of Yanmar, Beta and Mitsubishi used in canal boats. While building in a double bottom, either sealed or open with a cooling coil is common in steel boats, not sure about how that would work with aluminium, although aluminium is commonly used in high performance car radiators.
