pandos
I have just partially rebuilt my MD21B. It was reluctant to start and I suspected timing was out
I took it apart and redid the timing and it was possibly a tooth out. All marks now line up perfectly, including the timing mark in the pump (including the internal one )
It started pretty easily then but was very noisey...as it was late I left it...
It was turned over by hand and it seemed fine with very high compression...
Plenty of oil and it was well oiled when being assembled.
Any suggestions on what I might try to establish if the thing is crocked ...
In the absence of a better suggestion I propose to run it for half an hour to see if it explodes or improves...
I think I can retard or advance the pump timing by adjusting the fixings on the pump so I might try this...
I could take out the heater plugs and do a compression test...and take out the injectors and listen for piston slap...
Anybody got a cheap md21b for sale ??
