Daydream believer
Actually, if you are doing the job properly you should be working to BS 5750 (ISO now but I am too old to know) with your tape which will be listed in your register of tapes. Checked for accuracy.
There was a big fuss years ago when the quality management schemes were introduced. Building companies were expected to ensure that they were checked regularly.
One day we had a a large number of mis fitting components in my workshop. This caused an argument. It was also costly. I took the tapes off several employees & laid them out. We had Rabone & Stanley in the mix. Sources which one would expect to be accurate. The difference in length was amazing. As much as 10mm in 3 metres.
After that, all our setting out was done with a number of 1 metre steel rules. Each one checked against the one held in the office prior to use.
I purchased a wheel from Screwfix & was measuring a property about 50-60 metres long, with projections along one elvations. The other side was just flush. I added up the dims from the side with projections, to check for mistakes ( something I always did) & i was 1.5 metres out. I did the measure again & this time got different readings both sides.
In the end I took my glass fibre survey tape & spread it over the ground & ran the wheel along it. Each time the Screwfix wheel recorded readings varying by up to 1.2 metres in 30 metres.
I then purchased a tested laser unit(circa £450-00 at the time) from the RICS ( one of my professional institutes), which I still have & have found to be extremely accurate.
