pvb
Shome mishtake, shurely?
Oh, it'll probably be refuted by someone.
Useful to refer back to that just to show that nothing has changed. There are people that only see what they want to see.
On their own the glass has better tensile strength the resin has better compression strength.
I think there is some selective reading of my post on csm here. My principal point, which seems to be getting lost is that there is no automatic correlation between weight and quality as adding more heavy stuff in yacht construction is cheap. All boat builders use a mixture of directional matting with other processes, I know that. In the past I have seen films of Bavaria amongst others using large amounts of sprayed in csm and looking at the inside of some of their admittedly older, second hand boats you can see this. If they no longer do this then I stand corrected.
Back to the original thread...
Interesting article in the new edition of Yachting World
3 New 36ish foot boats from the drawing board of Stephen Jones
Rustler 37 - Very Traditional, looks like it will be a hit with many on here - but £262,500 ex VAT
Southerly 36 - Raised Saloon, modern looks, twin rudder and lift keel - £235,000 ex VAT
GT 35 - Discussed to death above - £241,250I
Interesting similarity in, very premium, pricing, bur rather gives the lie to those suggesting that a cheaper alternative to the GT35 would be to ask Rustler to knock out a new Starlight.
Mr. Jones does know how to design a goodlooking, seaworthy and fast boat ...
It is not clear to me whether the new Rustler is just a reworking of the Starlight drawings or a different boat altogether.
Of the three, the Rustler and the Southerly are differentiated from the crowd, and so give you an obvious reason to consider buying them if they met your criteria. Sadly, the GT doesn't seem to have any compelling distinguishing characteristic that asks to be added to a shortlist.
So which one should I buy in 13 years when I sell my business. Can you expand on the pros and cons of each one?? Beyond the obvious lifting keel/long keel.
What slightly concerns me is that they are so expensive that no-one will buy any of them so there won't be any second hand ones in 10 years??!!
If you fancy a boat which will sail quickly, light and airy deck saloon and the ability to explore shallow areas and dry out then the Southerly.
If I were feeling flush, then I would buy one like a shot.
The reason being is - I own a Sadler 290, and this looks like a scaled up fin keel version. It will go like stink in a blow and be very strong, and very safe.
[/URL]![]()
[/URL]![]()
In fact, if Rampart yachts had been a little more enduring, I would have bought their proposed SJ designed Sadler 340 which the GT35 looks very similar to.
SJ came out on my commissioning trip with my 290 - hull number 3 and he is a very clever chap. This boat will sail well, and it will do this in far more satisfying way than anything Swedish.
Full marks to GT for picking up the baton, but can we have a more affordable version please.
If you just want solid then the GT35
