amun1000
New Member
Hi - hoping someone can shed some light on the issues we're having with the engine at the moment.
Essentially the engine is having difficulty starting but once going runs fine. If the engine is cold it will take a number of prolonged attempts to get it running. Once warmed up the engine is stopped however any attempt to restart will require 3 -4 attempts using the starter motor. It fires but without the aid of the starter motor it will peter out. Eventually by the 4th attempt the engine will gain enough momentum and start running without the aid of the starter motor. It seems it starts bets with the throttle position at about halfway. I have tried a number of things to identify the issue such as partially blocking of the air inlet (choke) t ohelp force through fuel
I have checked the following things:
Lift pump - with the bleed screw loosened i can see the lift pump is creating pressure
Drained and Cleaned Precipitation tank
Inspected fuel filter.
Turned engine over with bleed screw loosed. There is plenty of fuel being "pushed" through to the cylinder head
There is no sign f any leaks to reduce fuel pressure for this non-glow plug engine
Hoping someone can help because as it stands the engine is unreliable
Thanks any advice greatly appreciated
