thomasx
New Member
Hi
I have had some intermittent starting issues with my Yanmar 2GM20, sometimes when I press the start button, nothing happens.
I see some say to connect directly from the start button to the solenoid with a new and lower gauge wire. So I did that. However, the wire that's always been there is the same as always, so changing for a different wire is really just "covering up" for something else. This was more or less confirmed when I noticed that after the swap, parts of the starter button had melted. So, at one time when I had this problem, I measured the current, and when pressing the start button, a very high current was drawn. Hence, the problem was not the connection, in which case the current would be weak, too weak to get the solenoid to act.
Then there are some solutions to add a relay next to the solenoid. That's one way of overcoming the issue with the high current melting the starter button. But the original problem is still there.
So, my belief is that the issue is with the starter solenoid itself, after years of operation it's not working as smoothly as before, and requires more current to act, and sometimes get stuck. A couple of times when the motor didn't start, I tapped the solenoid with a tool, and both times it started perfectly directly after the tapping. So this strengthens my belief in the solenoid issue.
So, now the next step is to remove, disassemble and service the solenoid. Did anyone do this before? Any experience, information etc, to share? Or any links to info on the web. I haven't found anything yet, after some searching.
Thanks, Thomas
Thanks, Thomas
