sebastiannr
Hi there,
Whilst in the marina I thought I'd change the coolant in the motor as I'd been meaning to do it for a very long time. I did it, brought the engine up to operating temperature and all seemed fine. Today I finally got the weather to make the passage across Biscay to Falmouth and 10 minutes out the harbour the engine starts over heating. I've sailed back in and am on the anchor.
I assume there must be a air lock in the cooling system, but I don't know how to bleed the system.
The motor is a Yanmar 3GM30F with a remote reservoir and a SureCal calorifier.
There are 2 drain points for the coolant, 1 near the oil filter and 1 under the heat exchanger. There is also a drain point for the sea water on the heat exchanger.
When I drained the coolant, no coolant came out of the drain point under the heat exchanger. I should've realized that was probably a problem, but stupidly chose to ignore it as plenty of coolant came out of the other drain point.
When filling the coolant, I removed the hose entering the exhaust manifold and topped up the coolant until it was full, replaced the hose and put coolant in the remote reservoir. That's all the book say to do. It says to check the level in the remote reservoir after running the engine and to top up as necessary, but the level didn't go down at all in the remote reservoir.
If anyone could offer any advice as to where I've gone wrong I'd much appreciate it - I've been stuck here waiting for the weather for 10 days and really don't want to miss this window!
Many thanks,
Seb.
Many thanks,
Seb.
