Lakesailor
Ask him.total height of vessel including mast lay along her deck MUST NOT exceed 12 feet for our specialised lifting service o 40k
Wounder if he means 12feet from mast base to end or the overlap aft?
As you mention height I assume it is a height restriction based on the route he would be using. Generally overhead lines etc must be more than 5.8 metres above the road surface, but some low bridges are there and can't be moved.
Question is....does he mean 12 ft above the road surface or above the bed of his transporter?
If he is using the right sort of equipment putting the mast on the trailer should be no problem. As long as a few strops are used to stop it "twanging"
