Wood filler for use on wet wood
skenn_ie
23 Apr 2007
Co Dublin
Does anyone know of a filler which can be used on wet wood ?. The stern quarters of my boat are a little chewed up, with lots of old screw holes. At the moment, it is not practical to get this complely dry. She dries out on every tide, but that's it.
ccscott49
7 Sep 2001
I do not know of any filler that will work on wet wood, however, if on one tide you use a waterbased 2 part epoxy saturator, as sold by John at Tradboats, Beccles, the next tide, you could use epoxy filler, which would stick to the now hard, water based epoxy. Remembering that epoxy filler does not go off as fast as polyester filler, which you will not be tempted to use! Reason being, polyester filler is agroscopic, it absorbs water, ask any good car body shop man.
Woodlouse
7 Jan 2006
Behind your curtains.
I probably wouldn't use it myself, but Hiscock in one of his books mentions cement as a wood filler. Other than that I can't think of anything else likely to even begin to be able to stick.
No chance the repair can wait until you can get the boat out of the water?
fishermantwo
20 Jul 2003
NSW. Australia
In Australia we have a product made by Selley's called Knead it, marine version. It is an expoxy that comes as a sort of tube with the two parts separated. To use you cut off the desired amount, knead it till the colour is uniform them jam it in the hole to be fixed. I have used it underwater to fill a gap at the stem where the planks join on my fishing vessel. One bloke in the dinghy mixing pieces the size of a cigarette, diver in the water jamming in filler with hardwood wedges. Goes off after 15 to 20 minutes. The plan was to replace the filler when next on the slip but it proved impossible to get out. Forcing the filler in with wedges obviously displaced the water and made a T section behind the plank. Its going to be there a very long time.
Lyulph Hesling
10 Jun 2010
UK swimming pool sellers have a two pack underwater sealant, as described from Oz above. It works well, and I used to carry some for "emergencies". Cannot recall name, but something like epoxy putty.
DownWest
25 Dec 2007
S.W. France
Saw somewhere an acct of a couple fixing a crack on their steel boat with cement and lanolin mixed quickly and applied underwater. When they finally were able to dry her out, it had to be chiseled off.
skenn_ie
23 Apr 2007
Co Dublin
Filler for wet wood
As the area is about 2m x 1m, putty types are not viable. The water-based epoxy might be the thing ... I'll ask Tradboats, and also wait and hope for more user reports.
The wood that is there is sound ... just a bit ripped, probably from having trawl(minesweeper) equipment dragged over it.
Shane
oldfrank
7 Dec 2005
Gorleston on Sea
Would it be unkind to counsel against a short conversation with Tradboats?
I always remember Tommy Cooper. He came on stage on day wearing a beret instead of his usual Fez. He said the the audience: "Who am I?" No reponse. Eventually, he threw the damn hat into the audience still crying "Who am I?"
To their silence, he responded: " Chuck Berry". Don't forget to ask Jonathan Greenaway what he has on his head!
Wicked Old Frank
