wiring wind instrument
transom
20 Oct 2013
I need to install a new wind instrument but the wind vane plug will not go down the conduit in the mast without removing all the exinting wiring and their termination plugs. this is something I do not wish to do. The wind vane manfacturers say you must not alter the cable lenght which is presumably critical. If I cut the plug off and solder it back on once I have threaded the cable down the mast will the instrument still work given that the total length of the cable will be 10mm or 20mm short. Does anyone have any alternative suggestions.
