richardabeattie
I have fitted a 12v twin socket - one side is a cigar lighter and the other a USB. But I cannot see any indication of the polarity. Does it matter? And should I wire them in series or parallel?
Yes it matters: I fitted similar a few weeks ago and there was + and - moulded in to the back of the sockets though not easy to see. Most plug-in charger-type stuff expects + at the pin of a cig-lighter socket..... And wire them in parallel, preferably with a fuse in the + feed. I used 20A as that was the max rating of the cig-lighter socket.I have fitted a 12v twin socket - one side is a cigar lighter and the other a USB. But I cannot see any indication of the polarity. Does it matter? And should I wire them in series or parallel?
Personally I would not want a 20 amp fuse on a USB socket. I would suggest using 2 separate fuses, one for each probably a 15 amp on the lighter socket and a 2 amp on the USB socket
More information will help, maybe a link to the suppliers page?, or part number or photo.
as has been said USB delivers 5V, if your socket does not contain a regulator then you might feed someone's iPhone with 12V, not pretty.
As a rule power outlesrs are nevere wired in series, unpluging one device will cut power to the other (as well as all sorts of jigger [pokery that happens if 2 are plugged in)
Another option would be to use a USB adaptor which plugs into the cigar socket. These can be had quite cheaply from eBay or play.com
He's referring to the USB sockets that the Chinese seem to be manufacturing by the million. Available on eBay and elsewhere for a fiver or so.
An example: http://www.banggood.com/USB-Socket-...o-Accessory-Power-Outlet-5V-21A-p-931962.html
Although that one appears a tad expensive (maybe there's the word marine mentioned somewhere in the description). The OP seems to have a double one with a 12V cigarette lighter socket & the USB charger socket.
They do give the right output. I fitted the first one about 12 months ago. No phones fried yet. Became so popular with crew I went back and fitted one in each cabin just to get their damned phones off the chart table.![]()
This is what I am trying to install. So I must look for the invisible polarity marks, wire it in parallel, fuse it at 5 Amps and hope the USB side delivers only 5 Volts.
I'll take it out again and look at the back more closely.
You could also just use a multimeter to test it in-situ. The button at the bottom of the 12v socket should be positive, the walls of it negative. Admittedly that's not much help for the USB side.
http://www.12voltplanet.co.uk/user/...-cigar-lighter-socket-cars-boats-vehicles.jpg
