robertj
I'm looking to replac the lofrans royal with a powered version.
Ideas on what you have and are you pleased with it etc?
34' 6.5 ton.
34' 6.5 ton.
The Lofrans Kobra would be the nearest replacement to the Lofrans Royal.
Either 800W or 1000W.
2 of the bolts are in the same position but the other two are in a slightly different position.
If you have a chain pipe your current hole may be circular. The Kobra has a rectangular opening for the chain guide so your existing opening is best opened up to match so you the chain falls through easily.
In addition, for the Kobra you will have to drill a large hole for the motor to drop through and you must make sure there is enough room under the current mounting position for the motor.
I've recently replaced a Royal with a Kobra. I used a large hole cutter plus router to make the mods.
... Recently used it to haul swmbo up the mast with zero effort. Used a spinnaker halyard which turned through a block at the bottom of the mast and then another block to give a perfect angle onto the capstan. ...
That sounds scary and was a concern I had so I went through all the blocks we had accumulated onboardband picked one where the pin is held captive by the housing - the first one of the images (not the actual block !)I've used the same method. You may not want to tell the wife the following as she may refuse to go up again.
The shackle post where it passes through the snatch block housing failed.
The snatch block was rated at 1500kgs.
Has anyone any views as to which type is best ?
Another vote for a vertical windlass with capstan. Recently used it to haul swmbo up the mast with zero effort. Used a spinnaker halyard which turned through a block at the bottom of the mast and then another block to give a perfect angle onto the capstan. Apart from the ease it also seemed to be a very safe method (also backed up with another halyard made off a points in the ascent).
Have not yet thought of another use of the capstan but it may come in handy one day to have what is in effect a powered winch.
Should you wish to consider other makes I can vouch for the Lewmar V series. These are very easy to install as the motor clips on/off. Have heard they are a little slow though but have not felt that to be a problem.
Yes, it is really down to personal preference and that one you have got certainly looks a doddle to install whereas ours (V3) has the motor under the deck so installation is a bit more tricky. The (removable) motor can be mounted in a choice of position but even so I ended up having to cut a bit of the bulkhead at the end of the forward cabin.My own personal preference is for a horizontal windlass. We use the Lewmar H series here. We find it very reliable and the speed is good, plus you are able to dump your anchor chain using the clutch. Easy to use and easy to fit. The one we have us the H3 at the bottom of the page.
http://www.lewmar.com/product-listing.asp?action=search&type=110
