waterline
Help required from a "newish" sailer on Windermere
I have just put a new Jeanneau SUN 2000 (22') trailer sailing cruiser on Windermere and was advised that as I was only going to keep the boat on the water for 7 months of the year, that I probably would not need Antifouling on the hull. My intention was to clean the hull as the boat came out of the water (possibly using a Karcher pressure washer). Well so far the boat has been on the lake for only a few weeks, and already the hull is becoming quite fouled with green gunge. My question is: should I have Antifouled from day one, and what type of Antifoul should I use.
I have also heard that boats kept on fresh water suffer more from osmosis, so again I am not sure if I should epoxy the underside of the hull prior to Antifouling to give a bit more protection against osmosis. or should I assume that all modern boats are less likely to suffer from these problems?
Any help much appreciated
