Wifi controlled desiccant dehumidifier
[2574]
29 Nov 2002
Has anyone managed to source a Wifi controlled desiccant dehumidifier? It’s 520 miles for me to drive to the boat to switch it on/off. Always left permanently on in previous winters but technology moves along and it’s nice to make the most of it.
If it’s 240v and you have wifi access then you could utilise any one of a number of ‘smart plugs’.
Yes, thought of that, but my Meaco junior, fabulous little dehumidifier, doesn’t like having the power turned off without it’s shutdown routine and won’t start after the power has been turned back on again unless it’s Start button is pressed.
The control panel on the dehum we have at home packed up years ago so we just wired the compressor direct to the power lead.
I have a EcoAir DD1-Simple. It is quite happy to be turned off and on at the socket (perhaps the clue is in the name) so would work with a smart plug.
Is your current one left perm on (burning energy all the time and trying to dry even the driest boat) or powered up and switching on/off according to its internal humidistat? If the latter what benefit does wifi bring?
Is that a desiccant one? The biggest cause of dehumidifier fires is not doing a cool down on desiccant models, which get very hot. Its not important with compressor models but if yours is a desiccant (I couldn't find a spec online quickly) then I'd suggest not turning it on and off by the mains
Interesting - the marina I was in last year had a dictat that only desiccant dehummers were permitted because the others were a fire hazard at low temp.
One way of achieving this is turning off the shorepower by a phone app or of course only have a limited amount of credit so it stops of own accord. Clearly depends on boat location though .
Below 5 degrees the compressors don't really work so I suppose they may overheat but the heat put off by a desiccant is enormous - running our small one will put the cabin temp up (in a 50 foot cat so quite some volume) by at least 5 or 6 degrees often more. When I forgot to set the timer on laundry mode to dry a few things in the heads it overheated due to the small space (about 2M by 1M by 2m high) and after 90 minutes had cooled enough to turn back on - it was locked out until then - and after 90 minutes, in the cockpit for safety, when I turned it back on the blower immediately started and put out very hot air and then tock a 10 minute cool down cycle to .. well cool down. Don't under estimate them
Yes it is. It has no cool down cycle, just a control knob to select humidity level. Stops instantly the knob is turned down. There is no other start stop knob.
My Maeco stays shut down checking each hour to see if it's needed. I rarely come to the boat and find it running. No need for remote control with that sort of sensing and control.
