Agreed, but how well would those mounts hold the engine in place if the boat is rolled? That's a heavy lump for a bit of glue to carryNot gravity, bonded rubber; the v-shaped steel section would have been thoroughly stuck to the rubber. Your mount is thoroughly knackered.
'Conventional' mounts are glued together and fail just as frequently as the more convoluted ones do. They're regarded as maintenance items in the car world - I've changed two very recently.Was wondering what possible reason VP had to design it that way? Surely 4 identical, conventional mounts would be simpler. Glued that block in, so no need to replace.
Invert the eng front, well suppose the back would invert too. Do you not have capsizes around Scotland? (strange thing to say) Anyway Not planning on that , but a spinnaker knockdown would do the same. The front of the engine just sits there due to gravity.
I did the gearbox spline modification, with the hex and the impact socket.
There is nothing fundamentaly wrong with that design. If the original bond between the rubber and the metal had not failed the engine would still be held in place by that bond if inverted. Virtually all engine mounts in cars and boats use the same principle. Car engines are designed not to fall out if rolled over so the principle is well proven by testing.Bloody edit not working! Why did they not design a conventional front mount? The engine just sits in this arrangement, I can lift the engine front and the v rubber part lifts with the engine. So if inverted the front of the engine wjll fall out. It needs that saddle bracket underneath to connect the 2 sides or it will spllay out.
In the days of my youth engines were bolted down to the bearers with bolts through hefty metal lugs and set on shims to adjust the alignment. The boat could be inverted without the engine falling out and a few did suffer inversion. But not many and designers along with builders adopted the flexible mounts incorporating bits of rubber glued to metal that are being described here. Such devices were first seen by me holding up the exhaust systems on cars, or failing to do so at embarrassing moments.
We have little or choice in this now. And as has been pointed out these mounts should be regarded as replaceable items that need renewed at intervals. Fortunately boats seldom invert, however eventually one will and the engine will break free and punch its way through the deck head, or whatever is normally above it.
Considering there are thousands of these engines out there, and very few, if any, reports of them falling out of boats I wouldn't worry about it ;-)
Considering that being rolled is a relatively rare occurrence, the number of boats with this engine still cannot can be a testament to the robustness of this mount. Being rolled is pretty disastrous by itself, so maybe we just don't get to hear from those that roll and lose the engine as a result.
