scotty123
And why dont I learn.....
Last year not long after buying the boat I set the local guy on to do bleed the fuel system on my 40yr old Volvo. In the process he snapped a terminal of the back of the starter motor but left me instructions on where to place the wire to start the engine.
I had to solder the cable back on.
Because I'm a gluten for punishment I engaged him again this summer when I had an over heating issue and lots of steam coming from the exhaust.
He removed the exhaust elbow and told me to clean and refit. This didn't improve the situation so he set about installing an expensive new raw water pump this didn't fix the problem and he left me too it not before leaning on my sprayhood and bending the frame and pouring an engine descaler down my sink and badly staining it.
After some internetting and tips here i back flushed the sea cocks and changed the thermostat and hey presto shes pumping water great and no steam.
I take her out for the weekend and find the bilge full of water. On close inspection of the raw water pump I see 2 of the 3 clamps have been broken and the pump is pumping sea water into the bilge.
I emailed him, got ignored. I rang and left voicemails , got ignored. Finally I receive a text saying hes been back down the boat and theres no leaks and suggests it's a rainwater leak from the cockpit??!
Am I wrong in thinking a marine diesle engineer should of had this sorted? The only benefit from this whole experience is that I've become alot more familiar with the engine and alot more confident working on it.
Rant over - dont use my 'local' guy
As a "gluten for punishment", I'd expect you to 'use your own loaf'.
