emmalina
only thing for me getting bigger is my belly
You were lucky.My coracle was the best. You could go out with the other hunter gatherers, run down a bison, scoop out the insides, stretch the skin over a few bent branches and hey presto, a boat. And in the evening you could all gather round the fire in a cave and argue (in a never-anything-but-fascinating way) over which is better, these new-fangled skin stretched over bent sticks things, or just clinging on to an inflated animal gut like in the good old days.
baggywrinkle,
You mean like this?
That probably is pressing a bit harder than is perfect for speed. It’s not me, I don’t have a picture of my own boat flat out, it gets a little busy. But max speed in a Dragonfly is shortly before the main hull leaves the water, they have sufficient float volume to do that, about 200% of displacement. That means that it should only be half submerged. In practice, in waves that means it varies between 10% and 90% submerged.I've never sailed a trimaran but I can't believe letting the lee hull dig in like that is good for speed. Momentarily easing the sheets or luffing up a little with the gusts seems better.
Even worse by implication. It’s an escape hatch, for when you’ve proper overcooked it.OMG it's got a window in the Hull!!![]()
Catamarans get one in each hull. It's thoughtful of designers who put them in the heads to not put the heads in same place in each hull.....Even worse by implication. It’s an escape hatch, for when you’ve proper overcooked it.
I suppose needs must, but entering a room with an upside down bog in it is desperate last resortsCatamarans get one in each hull. It's thoughtful of designers who put them in the heads to not put the heads in same place in each hull.....
Definitely.Just goes to prove, you need more than 1 boat![]()
Depends if you want to do this ....
... or this ...
I remember specifically choosing a route so I got to fly on a 747 when they were new. And even got upgraded to 1st class on that one flight, possibly because I was rather scruffy. But I didn't know 380s have gone before I got to fly on one. And airports had to reconfigure to fit them in, too!...
Strangely most commercial aircraft are getting smaller after the demise of the 747 and Airbus 380.
Was that a self-inflating gut? ;-)My coracle was the best. You could go out with the other hunter gatherers, run down a bison, scoop out the insides, stretch the skin over a few bent branches and hey presto, a boat. And in the evening you could all gather round the fire in a cave and argue (in a never-anything-but-fascinating way) over which is better, these new-fangled skin stretched over bent sticks things, or just clinging on to an inflated animal gut like in the good old days.
Plenty of 380s working. Try Emirates. Its Brill for passengers.I remember specifically choosing a route so I got to fly on a 747 when they were new. And even got upgraded to 1st class on that one flight, possibly because I was rather scruffy. But I didn't know 380s have gone before I got to fly on one. And airports had to reconfigure to fit them in, too!
A club associate went on a coracle-making workshop about 15 years ago. I think he made a coracle in one day but I have not heard that he put it to use. I see that there are a number of such courses still going, though I think I'll give them a miss. I don't really like getting wet.....and everyone agreed the best Anchor for a Coracle was a rock on a length of vine, you had to paddle backwards slowly to set it, obvs.
They're no longer in production but plenty still in use.Plenty of 380s working. Try Emirates. Its Brill for passengers.
I read this morning that the final assembly line for them has been repurposed and has just produced their first narrowbody for which their order book is bulging.They're no longer in production but plenty still in use.
Seems like Airbus gambled on the hub+spoke model but point-to-point won out.
Interestingly, the lowest fuel consumption per passenger is currently the Airbus A220, which is not at all large.
