Why are GRP gaffer masts usually wooden?
Greenheart
29 Dec 2010
Very basic question, which I apologise for giving no forethought at all.
Cornish Crabbers, Cape Cutter, Heard 28, Memory 19, lots more, all built mainly in glassfibre but all (or almost all?) have wood masts.
They're very attractive, but is that the main reason for choosing a wood mast rather than metal, like nearly all boats that aren't retro-styled?
Is the use of wood for spars, a decision made by the heart and regretted by the head? Or is wood genuinely as good, or even better, than alloy?
Egret
15 Nov 2024
Maybe something to do with the kind of point loading from a gaff jaw which might be at various levels or that a suitable round aluminium section just isn't available - someone from one of the builders or mast manufacturers will no doubt respond.
Tranona
10 Nov 2007
Yes, there are no off the shelf aluminium masts available although some boats have used carbon masts. For straight pole masts on smallish gaff rigs wood is still cheap and easy to make plus in tune with the ethos of the boats.
Laminar Flow
14 Jan 2020
West Coast
Thomas Colvin, USA, designed many traditionally rigged vessels using aluminium pipe for the spars. This material is readily available in various diametres and can be easily sleeved to lengthen.
By cutting darts and welding these up, the spar may be tapered as well.
A great many of the Dutch traditional craft use steel pipe for their masts, as do most of the traditional square rigged ships these days. Both lighter and stronger than wood in the larger sizes.
