Quandary
A thoughtful, informative and impartial post -
- Your sort are not wanted around here![]()
Not by the exclusive brethren anyway, how dare you express an opinion!
Bavarias had a problem with their keels a few years ago ......
As with all the modern cheap production yachts, they have bolt on keels that have an almost vertical leading edge and just a simple flange mount directly onto the hull, rather than having a stub moulding or an integral keel. They are also made of cast iron rather than lead (lead distorts on a heavy blow). The problem with this arrangement is that they are more vulnerable to grounding damage than a conventional fin or long keel with a well raked leading edge which allows the boat to drive up onto say a sand bar rather than come to a sudden stop. Just look around the marinas this winter and check for distortion in the hull at the back of the keel and for kinks in the shear line around the main bulkhead. AND yes most yachts end up hitting the bottom sometime ...... and it used not to be a problem!
However I am sure they give many people plenty of fun and space for few £. In a few years they'll be even cheaper as the secondhand market will be even more flooded with them. Unfortunately this causes the rest of the secondhand yacht values to go down with them....... I guess this is what causes most of the bad feelings.
I could go on ..... but most of you have heard it all before.
The hierarchy and snobbery that surrounds some areas of boat ownership is unbelievable.
Robin, you speak of your Sun Legende in the past tense, you say our "last boat", do mean last boat, or current boat? Just curious.
I am really surprised no Bav owner in 96 post has challenged what was said here.
That's because one of the previous Bav threads turned into a Bav owners love-in. Gotta take turns
Bav lovers & Bav bashers: never the twain shall meet (or at least as little as possible)![]()
Anything cheap and popular generates disdain – it's a relic of the English class system. In addition, intuitive perception is absorbed, osmosis-like, and governs how we judge a product.
Perhaps it is unfair to resurrect an old chestnut, but here goes.
For many years I didn't distinguish Bavaria from any other of the mass-produced boats. I recognised that yacht design had moved on and by clever marketing focused on the desire for larger, family-oriented cruisers. I had no doubts that they admirably catered for that volume market – I just wasn't a part of it.
Then, in 2005 when cruising the Croatian coast, I was close to the now legendary tragedy of the Bavaria Match 42 incident where the keel was lost and in which a crew-member drowned. Suddenly the marque Bavaria was highlighted in my mind and, as practically a neighbour of the accident, I researched everything about it on the Internet. The Hungarian club that had chartered the team of yachts posted a mass of details and photos and I could hardly believe what they revealed of the keel-hull joints, not of just the stricken yacht but of many other Bavaria Match yachts in the regatta.
But what was even more unbelievable was the damage limitation press release from Bavaria that claimed the keel loss was due to hitting a rock, long before any evidence was available. This was subsequently and successfully refuted and a report by Zucker & Partners, a German marine surveyor, clearly blamed the design and construction of the boat. Activity to recall and modify hundreds of Match 38 and 42 yachts then began all over the world, with practically no publicity whatsoever.
I am sure that all other versions of Bavaria yachts are properly made and seaworthy, that it was just that particular model at that particular time that was faulty. But, however hard I tried, I could not separate the product from the despicable knee-jerk reaction of Bavaria Yachtbau GmbH to the accident and, as I wrote above, perception is important and I have since been prejudiced against Bavaria ever since – irrational I know, but that is human nature.
Incidentally, before writing this I again did a Google search on the subject – all my old links turn up 404 errors, even the survey report is no longer available. Just a few of the Hungarian and German yacht magazine articles remain, here and here, plus a multiple-page thread from a forum of yacht designers, here. Another forum thread with the Bavaria press release is here.
Robin
The very best of luck. I do hope that your crossing over to the dark sidedoes not mean we will see less of you on this forum.
You might have a point as my experience of sailing Bavarias has nearly always been on Sea-School boats where the sails were not in the prime of their life. If the new sails are cut a little full, then its no wonder that my experience is what it is.Hi John,
I bow to your greater experience, however I could note the following points after owning a bav 34 for the last 9 years and using it a great including sail training for a time.
The original Elvestrom sails are just too full and designed for light wind sailing. With them I found the optimum reefing speeds of 18, 23 and 28 knots to keep good control of the boat. You also needed a lot of backstay going upwind and obviously when you reefed the headsail it was a bag of the proverbial
I have replaced the sails with Crusader sails about 3 years ago and it is a different boat.
If the wind isnt too gusty we can now leave the first reef until about 22-23 knots ( although I still tend to reef a bit earlier so as not to overpower ). Indeed I had a total novice broad reaching with full sail at 23 knots apparent and going straight as a die, while other boats around us were steering some very dodgy courses. A larger Moody which was overtaking was really struggling to stay clear and called for water. My novice just turned right a bit and let him pass.
With one reef in, averaging 20 with gusts to 30 are still a bit of a problem but more manageable. With 2 reefs and the same winds we average a little slower in the lulls but no drama upto 30 knots gusts.
Not as comfortable in a seeway as the rassys and such like, but I have no intention of changing mine.
Regards
I would be very interested to sail a Bav 34 with new sails and am quite prepared to take back all I have said. (I also emphasise that my comments probably apply equally to several other modern fat bottomed boats.)
I still go sailing on Bavarias, but I know that the way that they (and other modern boats) sometimes behave isn't the way it has to be.
.. he lacks the cultural capitol to progress to full acceptance.
You are a sociologist / sociology student - you just have to be with comments like that!
By the way, it's capital not capitol, unless you are a Congressman or the like.
But then a whole batch of Starlight 35's had gelcoat failure... and didnt the Centaurs have a bunch of rudder failures as well??
Moody have had problems too, and Benny had a major issue with duff gelcoats and osmosis, Hanse have had rudder problems, Bav the well known keel problem plus other. So what? If your Merc breaks down it doesnt suddenly become a Renault.
