chris-s
After being persuaded by you lot to use a splitter rather than a separate ais antenna, I returned the antenna and orders a splitter. I eagerly fitted it all last evening. However, it was showing an error light when transmitting on high power. I also took with me a spare banten antenna/cable with the idea of transmitting ais on that and checking I could receive it.
When using this antenna instead of the masthead, I do not get the warning light.
After a bit of swapping bits around it looked like using the masthead antenna was not working very well. We rarely use the vhf tbh, so might not have been aware of an issue.
This was a new antenna last year with all new cabling and connectors in one single unbroken length all the way to the radio. Being so new I was surprised at this.
This evening I took down my zetagi 102 swr meter. I know how to use it, and when testing between the radio and the masthead (no splitter) I couldn’t get it ‘set’ to the max division, only as far as ‘20’ on the ros scale, then when checking it the needle went right up to 15. Clearly something wrong.
Testing with the spare banten antenna/cable gave readings that I would expect to see as more sensible.
A quick look up the mast and the antenna is still there (you never know).
Other than pulling the connectors apart, or swapping it all out I’m not sure where to start. I know it doesn’t mean much,but I stuck a multimeter on the ends to check for open/short circuit and both antennas read just under an ohm.
The connectors are m&p weatherproof ones so should be good quality. The cable is labelled “M-17/20-RG058 MIL-C-17G 50ohm”, again, this is supposed to be a good quality cable. I don’t recall what the antenna is, will need to look back thru my emails for a receipt.
Right now it looks like rather than having a short stumpy ais antenna on the pushpit, I’m going to end up with a flipping great banten job.
Thoughts on finding the fault?
