Where o Where
Can I get a large drop nose pin for my stem head. needs to be approx 210 mm long?Tried Google etc
I bought a couple of different length ones not long ago at Fox's, Ipswich ... just checked and you can get them from their on-line store ... all different sizes ... you should get what you want from there.
Not long enough need usable length of 200mm
If you get completely stuck give me a shout and I'll make you one; 316 stainless, threaded one end with a stainless dome nut, either drilled at end for pin or could probably make a proper drop nose end if you prefer
If i were you i would call it a " stick it in the stemhead fitting thingy"
After all this fuss an inexperienced crew may take "drop pin" literally
In fact with nothing better to do than moan about the title some readers may like to dream up a name
( note ---"a stick it up your ------- pin " will not be allowed)
Thanks, Long John Silver is sending me one to try and if all else fails will get back to you.
