Where does the butter melt?
Allan
17 Mar 2004
Lymington
When we crossed the Atlantic we were given a point (lat/long) to aim for before turning right. My searching of YBW and the wider internet have failed to find it. Can anyone help? To be clear, it's the approximate place to turn right, in the advice 'head south until the butter melts and turn right'.
Allan
ylop
10 Oct 2016
I assumed, that if there was merit in the description, it was not as simple as turning at a particular latitude (else just give a number) but rather that at different times of year the butter melts further north/south and the calmer weather follows that. But I've never planned an Atlantic crossing so I could be reading way too much into a crude navigation instruction.
Allan
17 Mar 2004
Lymington
Yes, I know the two things sound contradictory and, from memory, I think the lat/long is seen as a more precise way to plan. Also from memory, it does take you at least a little to the west, not just south.
Allan
Blue Seas
29 Jun 2024
The combination of both Weather Forecasting and Butter is even better than the sum of its parts.
I study the forecasts to determine the POB then, on my route plotting chart of the Atlantic Ocean (Northern part), I carefully plot the POB (Point of Butter) for that particular day / weather forecast. When heading S/SW and passing say Portugal I always aim to leave the POB to starboard. I once made the mistake of cutting the corner off by rounding inside the POB but the butter immediately re-solidified and never tasted the same again.
After that little scare I would no sooner pass inside the POB than set sail on a Friday or carry a woman onboard.
john_morris_uk
3 Jul 2002
At sea somewhere.
There’s no defined latitude. And although the traditional advice about when the butter melts ‘sort of’ works, you’re better downloading some wind data and seeing where the trade winds are when you’re actually in those waters. (Assuming you’re play transatlantic?)
Out of interest we were getting weather routing on my last transatlantic and had got to the point where we were making a definite turn to the west picking up the tradewinds when we also discovered that the butter stored in a Tupperware container in the bilge had started to melt. Coincidence? Who knows?
Allan
17 Mar 2004
Lymington
Not replying to anyone in particular, but two questions:
  • What brand of butter?
  • Salted or unsalted?
OK, maybe I should explain. I'm attempting to write a book about two Atlantic crossings. In a previous chapter I've said some very positive things about the YBW forum and in particular I've mentioned 'TCM (Matt) and Stingo' as being very knowledgeable and helpful. In one chapter I've mentioned the waypoint I was given but I'm struggling to find the exact position.
Another quote 'After one morning watch I mentioned to the skipper that, if we didn't have a fridge, the butter would be starting to melt'!
Allan
Stingo
17 Oct 2001
Getting drunk with your daughter
Allan
Well, a comment like that just might give me a swollen head. I wonder if I'll fit through my companion way later?
But thank you for the compliment. Much appreciated.
Allan
17 Mar 2004
Lymington
No problem, I wonder if you remember two Moody old blokes sailing across to St Martin for the weekend in March a few years ago?
Allan
