dylanwinter
new window in the duck punt so that I can film the fishes
The mistake you made (from what I could see on the video) was to fully tighten the screws before the sealant had cured. By partially tightening the screws and letting the sealant cure forms a gasket, then fully tighten the screws and you should have a water tight seal.
The ports on my boat are fixed on in the same way; when I got it they leaked - not enough sealant, it had all been squeezed out. When I resealed them I put washers on the screws between the acrylic and the hull, then you can tighten them down and leave a thick enough band of sealant...
A dinghy on the beach near mine has a window in the bottom a bit like yours. Over the years the acrylic has gone opaque and now cracked in the sun.
My first thought was of horror. Cutting a hole in a perfectly good punt to photograph fishes.
I don't think this will be a success. Anyway a man has to do what his bright ideas lead him to do.
A dinghy on the beach near mine has a window in the bottom a bit like yours. Over the years the acrylic has gone opaque and now cracked in the sun. Obviously the dinghy is not used anymore!
A water proof camera might have been a better idea IMHO.
Anyway good luck with it. No it won't leak. I hope the fish are cooperative. Try dangling a bag of food outside the window. Like they do for sharks. olewill
Given that there will always be more light camera side of the window than fish side, how will you deal with reflections off the window?
I think light will be your biggest problem, or rather the lack of it underwater. You need to fit a couple of 1000 watt underwater lights!
That will be his next project along with how to water proof them !
Check out the the MoBo forum, they consider u/w lights to be an essential boating item. There is even a dealer that posts there. But be warned thet prices are in line with other top of the range MoBo equipment. Oh & Dylan will need 3x110ah batteries & a generator in his punt to power them.
