When to get engine serviced
installer2
9 Jan 2019
I have a Jenneau 645 with 115hp Suzuki outboard. How often should the engine be serviced? is it once a year regardless of hours, or for every set number oif hours?
I don’t know your particular motor…but most manuals I’ve read say x number of hours or each year which ever comes first
I know it is a different type of engine, but my honda 30 was serviced once a year regardless of hours either by a main dealer or myself.
Honda did a service kit which made life easier, though sometimes I did wonder whether it was worth changing over a perfectly good item. But when having to motor across channel due to no wind, I would hate the engine to pack up middle of shipping lane through something I didn't change.
Use the table from the Suzuki manual, the one posted above looks the same as for my DF200 but look up your specific one & a UK version incase it differs.
My boat is currently out of the water so even though it’s not due a service yet it seems sensible to do the oil & gearbox before it goes back in.
From new its the manual, however after that, most skippers will have "consumables" changed on an hours run or fixed period, whichever is comes first.
In my case its 150 hours run or every 12 months , oil and filters plus check gearbox oil for level and clarity.
Every 2 years, a change of impellers regardless and usually secondary fuel cartridges.
Everything else on condition.
The engine service items cost peanuts compared to the total cost of boating.
For peace of mind it is worth doing by the book. An engine which becomes unreliable is a PITA. One which needs replacing is expensive.
Servicing an engine is cheap compared to servicing the seals for an IPS drive with its special oil made from gold and pixie dust.
AI advise..
"For a 115hp Suzuki outboard, the service interval is generally every 100 hours or once a year, whichever comes first, starting with a crucial 20-hour break-in service for new engines, with tasks including oil/filter changes, gear lube, and water pump checks to maintain warranty and performance. Always consult your owner's manual for specific details, but expect major services at 100, 200, 400, 600, and 1000 hours, focusing on vital components like fuel filters, spark plugs, and anodes. "
