So here I am making up my list of must-haves, would like to have, have to get rid off etc. etc.
Why - boat destined as many know to be sailed from Solent to Baltic .... and like many of us - I don't want to miss out anythiung essential or advised. It's a tricky one as the boat is not so big that I can carry steamer trunks of gear - but it must be sensible.
So here goes .... What would YOU consider a) essential, b) well advised to have, c) good idea, d) thats nice but could be left off if becessary, e) luxury only if space available .... now consider that this is a 25ft motor sailer .... Sunrider 25 - very similar to Colvic 26 / Westerly Centaur .... There will be 3 people on board. Layout is typical 70's .... longitudinal galley stbd side main cabin. Stowage under stbd cockpit bench via trotter box. Double bunk / dining table combo to port and sea-bunk used for stpwage aft under the cockpit. Heads to port between main cabinb and forecabin, hanging space to stbd. The forecabin is typical vee-berth twin with 10 gal water tank under port bunk, 70 ltr fuel tank under stbd bunk.
We have 40HP perkins engine driving large 3 blade and a suit of sails in mod-heavy cloth etc. just refurbished. Fire extinguishers to replace or service. Flares to supplement with new - keeping old as extra.
There's plenty of 12V socket to run gear, total of 200 A/hr batterys and good charging from engine which likely will be run for 4 - 6 hrs per day ....
Trip will be split into 24-36 hr legs and occasionally 48+ depending on weather and winds etc.
So from the above - you can assume limited stowage and adequate fuel /water for 3-4 days - longer if winds favourable and economic with supplies.
So go on - give me a comparison with my list ... this should be interesting as I have not given a budget to work to ...........
Finally which way would you go ..... with a bit of detail why .... and of course when .... ?????
Interesting exercise .... and I can assure all that the crew who go will be fully involved in similar to ensure we have what we need to complete this voyage ... Boy am I looking forward to this ......
For those interested - I have plans to really put to test my PC Chart program as a part of the GPS Nav Group I run ---- so the program of tests will be in real time and real situation ... hopefully with no emergencys ....
