longjohnsilver
I decided that I wanted to get Eos coppercoated, and it was suggested that a local yard would do a good job. No names given at the moment. Quote accepted, the yard then employed an outside contractor to gritblast the hull to remove the old antifouling. This was done a few months ago and the result was not quite what i expected, in places it had removed both the original epoxy coat and created small holes in the gel coat. However probably 95% + of the hull was still blue with a thin layer of old antifouling.
I had a surveyor around this week to do an insurance survey and he expressed surprise at what he thought was a poor blasting job, not so much because of the voids but more about the non removal of all the antifoul. His opinion was that if we coppercoated as is, the coppercoat would soon fall off as it was not being applied to a sound basis of gel coat or primer. The hull is perfectly dry and the voids are just small air pockets which the blasting has opened up. They can all be filled reasonably easily with epoxy filler.
His recommendation was to get the blasting firm back to finish the job, then prime and fill where necessary, then proceed with the coppercoating. However the yard has just phoned me to say that they are very reluctant to continue along these lines due to what they see as potential further damage to the hull. And doing it manually will be far too time consuming. They propose filling in the small voids currently visible, priming and then putting on conventional antifouling, and not charging me for the blasting carried out. They are trying to be reasonable and are good to deal with, I don't want to cause problems which could change this.
However, I still want the coppercoat as planned but really don't want the original firm back to carry out any further work. So my thoughts are to get someone else in to take off the remaining paint, apply filler where necessary along with at least one layer of epoxy, and then coppercoat. But that goes against the recommendations of the yard.
Initially my thoughts as to other options are to use an antifouling stripper or a powered scraper, but the scraper would be time consuming and very hard work.
Any other opinions or suggestions are welcomed as there are undoubtedly other angles I've not thought about. Thanks.
