Andy Bav
Want to get a kedge anchor and forum has suggested a Danforth. The question, is what weight to get if used as a kedge, rather than main anchor, or does the weight formula for boat length still apply ?
If your kedge anchor is doing the same job as the main bower anchor for e.g. fore and aft mooring in a river, then it needs to be the same size to do that same job.
On the other hand if it is tasked with smaller loads, you can go to a lighter anchor. If anchor or handling weight is a factor from a dinghy , then a Fortress or Guardian is a good choice..
Thanks, in the Med so no current. Just want to keep her facing in the same direction, so more to arrest lateral (swinging) movement.
Well it's not a storm anchor just to keep you in line with your neighbors and my folding grapple you can open as many flukes as you want and then lock the collar but in truth gravity keeps the uppermost flukes folded flat so the collar isn't necessary. They also don't take up room on your boat and don't pose a risk to your inflatable if that's how you deploy it. But the lack of injury to other beach goers is the main advantage.
Just my opinion
I've also seen boats lined up close to shore with small low-spec anchors out the back in shallow water, but it has always been smaller sportsboats and RIBS. If i'm not mistaken Andy has just bought himself a V42 so is likely to be anchoring further out where there would be no risk to beachgoers.
I suppose the guardian/fortress is a good option, although I wouldn't say they're that easy to store due to the long cross-bar.
I think to make fore and aft anchoring work you also need more bow chain, so you can let out a stack of chain at the front, drop the kedge straight off the back of the main boat, then pull in at the front whilst paying out at the back. I found it a nightmare trying to use the tender to drop the kedge, though I admit I didn't really stick at it. I also found it just doesn't work in busy anchorages, because everyone else is swinging.
Also I am trying to get my head around how you recover both anchors if you go for the pay out at stern as you winch in at the bow, system when setting the anchors if there are only 2 of you on board ?
Surely you just let out on the bow while pulling in on the stern, until you're over the stern anchor and lifting it off the bottom. Then you pull in on the bow anchor same as usual.
The whole thing sounds like a complete PITA. We did a lot of anchoring in Croatia involving taking lines ashore and it was just a big hassle especially with just 2 of you on board.
Same in Croatia. In the end we were avoiding those places and seeking out more secluded anchorages. If you're going to be anchored cheek by jowl with boats on either side, you might as well be in a marina with shorepower to drive the a/cCan't disagree with that, but we did a charter in Greece last summer and several places we visited would not have had space to secure any other way.
We found it pretty easy tying back to rocks in Greece as long as someone is happy to swim to shore with the rope, and there is another crew on the boat to pull in spare rope and cleat off, while helmsman holds position. With less people, or using the tender, I can see it would be more of a PITA.
Yup its a 3 person job really and that depends on somebody being willing to swim ashore with the line which is not always a given before June![]()
