What type of yacht is this?
Rudyraff
29 Dec 2021
Hi there
Can anyone identify this type of yacht please, it kind of looks like a Halcyon 27?
Cheers
Frogmogman
26 Aug 2012
Don’t think so. The Halcyon 27 has a step in the coach roof, and the aft windows are bigger than that
edit
sorry, I misread your question. You obviously don’t think it’s one either
Fr J Hackett
26 Dec 2001
Saou
Both of those have transom hung rudders - this one has a counter and keel hung rudder.
You are right I was looking at the enclosed prop and general underwater configuration, the large counter should be a clue but I can't place it. I thought you might have a better idea
Elizabethan 29 but I don't think the counter was anything like as pronounced
NealB
19 Feb 2006
Burnham on Crouch
Just a vague guess:
MG 30, moulded by Somerset Plastics, home-completed?
Edit ...... the hull looks MG30, but the coachroof ..... probably not.
Tranona
10 Nov 2007
Just a vague guess:
Close, but the keel shape is different with a vertical front and the rudder is rounded rather than straight. My other thought was an Illingworth & Primrose design as they were keen on the vertical leading edge to the keel and short keel that left the rudder forward on the waterline. As Fr J Hackett says, pigs to steer - ask Chichester as the Gypsy Moth they designed had a similar underwater profile
NealB
19 Feb 2006
Burnham on Crouch
Hmmmmm .... I'll have to try and dig out some (paper) pics of our MG30 that we had many years ago.
I'm sure her keel didn't have a vertical leading edge.
These pics, from google , are just how I remember ours.
Tranona
10 Nov 2007
Similar pics o the ones I found. Front of the keel is swept back on the MG whereas vertical on the boat in question. Otherwise very similar hull shape.
NealB
19 Feb 2006
Burnham on Crouch
It might be my eyes, or the pic in the op, or the amount of weed in the op ......... but I'm not convinced that the keel in the op has a vertical leading edge.
Certainly a teasing question!
LittleSister
12 Nov 2007
It might be my eyes, or the pic in the op, or the amount of weed in the op ......... bit I'm not convinced that the keel in the op has a vertical leading edge.
The keel doesn't have a vertical leading edge. If you enlarge the photo you can see that the dark area that looks at first like a vertical front to part of the keel is actually behind the trailer/lorry carrying the boat (something on or behind the white van, perhaps?).
Spirit (of Glenans)
28 Mar 2017
Me; Nth County Dublin, Boat;Malahide
To me, it looks like a long clump of weed hanging down like a Spaniel's ears, giving the impression of the keel being straight at that point.
LittleSister
12 Nov 2007
There is weed hanging down too, but there is something wider/deeper (and darker/blacker) behind, the bottom of which is either horizontal, or the yet lower part of which is hidden behind the top of what might be a block on the lorry bed.
Tranona
10 Nov 2007
Agree that when you enlarge it there is something odd about the keel as there seems to be something missing at the toe. However if you look at the back of the boat the rudder is different with the lower pintle higher up so the rudder is much shorter.
NealB
19 Feb 2006
Burnham on Crouch
........if you look at the back of the boat the rudder is different with the lower pintle higher up so the rudder is much shorter.
Yes, I spotted that, too.
I wondered if that could be because many MG 30s were home finished?
Seems unlikely, I guess?
And, most certainly, the coachroofs are very different to the one in the OP.
michael_w
8 Oct 2005
It's either the same boat or a hull sister that's been lurking round the Orwell Yacht Club for ages.
