What type of drive on 'Brave Challenger"?
stuartw
30 May 2001
Berkshire
What type of drive on \'Brave Challenger\"?
As I was relaxing on my aft deck, in the relative peace of Haslar marina, yesterday morning, when I thought the world was about to come to an end. "Brave Challenger" started her engines. I am only 50yds from her and believe me I've heard less noise from an anti-aircraft gun. How many horses were trying to get out, goodness only knows- maybe 2000.
Having recoverd from the initial shock, I was somewhat bemused to hear that the engines were left on a very fast idle, I would guess around 1500 RPM. By the way, for those who thought that the engines were turbines- no the're not- just big, I mean really F***ing big diesels. And of course no silencers-straight out the transom.
This very fast rev warm-up lasted for some 10 mins, then off. They then spent the next hour preparing to go to sea. When eventually they did go, the engines were brought back to life, and once again the same very fast idle. She then pulled slowly away from the hammerhead, with no noticeable change in engine revs, ie still running very fast. She headed towards the sea, with the engines screaming, and only doing the regulation 6 knots.
We heard the row for at least ten minutes, which got louder at some point as she was opened up, heading out to sea. What the people on board must hear, I dread to think.
The puzzle is, what type of propulsion has she got? I have thought of variable pitch props, hydraulic drive, electric drive or even some form of automatic gearbox with torque converter. Clearly the high revs were on the optimum point on the power/rev range.
So, does anybody know, or can guess?
Solitaire
25 Jun 2001
Southampton
Re: What type of drive on \'Brave Challenger\"?
I'm also based in Haslar. In the 18 months I've been there this is the first time I have heard of her moving. As I understand it she is powered by gas turbines.
petem
Cotswolds / Campomanes
She has two 435hp diesels which give a transatlantic range. In addition she has three Rolls Royce Proteus gas turbines that together develop 12,750hp. These give 60 knots (not bad for 100 tonne boat).
She was built for Stavros Niarchos in 1961 and underwent resoration between 1979 and 1989.
Now, who can fix us up with a ride?
stuartw
30 May 2001
Berkshire
Now at last we are getting somewhere into what is fitted. But do you know what type drive is fitted? I clearly heard the engines on constant fairly high revs, so there does not seem to be a direct mechanical connection, ie a conventional gearbox between engine & prop. So there has to be some form of variable torque converter, hydraulic or even electric motors, which would of course would require big generators.
Perhaps you could enlighten me- I am intrigued
petem
Stuart,
The only other line of enquiry would be Berthon International who were selling the boat a couple of years ago.
charlie
14 Nov 2003
I reccomend that you ask the owner. His name is Wensley Haiden Bailey and is very approachable.
He loves the boat with a passion and knows her in side out.
I spent a very rewarding afternoon clambering all over and inside her. A beautiful and very impressive boat.
He can normaly be found on board.
Kind regs
Charlie
