Neeves
Post removed front answer.
Apologiers to Coopec.
A 1000w windlass will be fine.
DO NOT haul the boat along with the windlass. You gently move the boat forward under engine power, retrieving the slack rode with the windlass. Once over the anchor, the windlass will usually break the anchor out, if it doesn't do it easily, put the engine astern and break it out with the engine, then retrieve with the windlass.
If the chain is vertical from the bow you can't set the anchor, if you could you would be able to anchor in 10m of water with 10 m of chain.
Do you not know anything about anchors ?
FYI, i didn't say how big the windlass is on my 20t boat, just that dragging it along with the windlass is dumb, which it is.
I usualiy do the FWD trick to break the anchor out ... OK - I use a crappy old Plough anchor .. but I think it applies to all.
My reasoning is that most times - anchor shank will be generally in direction of the boat. So pulling astern will cause anchor to dig in further, OK - so we are talking about stem over the anchor .. so that line of pull is significantly out of alignment. But easing ahead - should cause anchor to either rotate or lift its shank ... breaking out in the process.
There is of course the 'wave lift' .... where you haul in tight, taking in more as the bow DIPS ... then when bow rises each time - its causing anchor to break out........
I have a Royal manual Windlass ... and I cannot remember ever using it for anchor. Its just too slow !!
Pretty much exactly my thinking.Having a sailing boat, I am quite happy to pull the boat ahead towards her anchor, using the windlass, without using the engine, unless there is a strong wind. When operating the windlass, all that happens initially is that the catenary of the chain is reduced, and that pulls the boat forward. This is of course, one of the advantages of using substantial chain, in my case, 10mm. If you use lavvy chain, you won't have the damping effect of catenary, and would indeed be pulling the boat directly, and could, if not careful, put an unfair load on the windlass.
I find in practice that the load on the windlass, when breaking out the anchor, is much greater than the load when pulling the boat ahead. All that is required is sensible use of the windlass.
Ahhhh, Gaios springs to mind....When anchored stern-to in Greece I find it best to not motor forward at all. Once the stern lines are released the boat moves forward as the chain falls to the seabed (catenary in action!) and a reasonably powerful windlass (1000 watts on 7 tonne boat) will comfortably pull it forward until over the anchor when it can be retrieved.
The result of motoring forward can be seen every day. The anchor drags across somebody else's chain and chaos ensues. If the motorer is really determined he can snag several chains, which makes it all the more amusing for the observer. Sometimes the motorer even manages to get someone else's chain around his prop. Great fun.
Patmos in the Aegean is crossed chain heaven. Wind blowing across the anchorage causes far more sideways drift than people realise.Ahhhh, Gaios springs to mind....
The clue is the word 'gently'. You and I might do it like that, if I was to use the engine at all, but many others give huge bursts of throttle. Combined with wind blowing across the beam in many Greek harbours this results in far more movement than is needed. To be fair, once the boat has left the quay it is difficult to know exactly where the boat is relative to the anchor.What's the difference between dragging the boat "forward until over the anchor when it can be retrieved." and gently moving the boat "forward until over the anchor when it can be retrieved." with the engine ?
How does moving the boat forward with the engine, retrieving the slack chain, until over directly over the anchor, result in dragging the anchor across somebody elses chain ?
I have never claimed to have any accepted knowledge on anchors.
I have an opinion that I express.
Once the chain is vertical and made fast, any movement, back forward or sideways, will eventually break out the anchor. (Unless it's fouled under an immovable object).
The release tension needed for an anchor is roughly equivalent to the hold that has been developed by your engine or wind. If you have the rode vertical and there is no chop and you reverse the engine the best you will do
as your engine will have insufficient grunt to shear the seabed adjacent to the anchor - the seabed's shear strength will be beyond the grunt of your engine to allow you to release the anchor.
You are the only person to mention 20t vessel and the only person to suggest dragging said vessel forward with a windlass. The thread is about a 6.5t vessel with a 1000 watt engine. As many have mentioned - using the windlass to pull the yacht forward should be well within the scope of the windlass. Your mention of a 20t vessel is outside the scope of this thread and outside the recommended size for a 1000 watt windlass.
As Coopec said - give it a break.
